Nakedtoes
- Dec 9, 2002
Yes.. Y..U buy from amazon uh…
The white color selling for 74 now at lazada
Black one for 71 now..Thanks man. The white one is slightly more expensive than the black one. Got it @ $82, still a pretty good deal
I think for running can try shokzHi all any decent and wallet friendly earpiece for running? Previously bought soundcore liberty recommended from you guys and zero regrets. But for running it keeps dropping so hoping for some recommendations in this segment. Cheers
Thanks. Price pretty steep. My budget <120 if possible hahaI think for running can try shokz
if normal tws are dropping while u run, can consider models with ear hook?Hi all any decent and wallet friendly earpiece for running? Previously bought soundcore liberty recommended from you guys and zero regrets. But for running it keeps dropping so hoping for some recommendations in this segment. Cheers
Redmi Buds 6 Play $11.50 from xiaomi physical or online store. Got mine for $7 during Lazada flash sale. The Buds 6 Play does not have ANC or multipoint but has great battery life while the touch controls can be configured in the accompanying app and are precise and not prone to accidental inputs. The buds are small in size and fit in the ears really comfortably. Sound quality also punches way above its price point. Been using these exclusively for my runs and workouts without any complaints.Hi all any decent and wallet friendly earpiece for running? Previously bought soundcore liberty recommended from you guys and zero regrets. But for running it keeps dropping so hoping for some recommendations in this segment. Cheers
Hey thanks for the suggestion.. do they get loose upon running? I have an in ear liberty 4 but it will loosen up during runs and I have to keep pushing back in. Or does the redmi ones sit much deeper in the ears?Redmi Buds 6 Play $11.50 from xiaomi physical or online store. Got mine for $7 during Lazada flash sale. The Buds 6 Play does not have ANC or multipoint but has great battery life while the touch controls can be configured in the accompanying app and are precise and not prone to accidental inputs. The buds are small in size and fit in the ears really comfortably. Sound quality also punches way above its price point. Been using these exclusively for my runs and workouts without any complaints.
Review: https://www.scarbir.com/tws/redmi-buds-6-play-vs-lite-vs-baseus-e19#block-21f0fdf76f6e33ede8e7
I do have to adjust the redmi buds once or twice during my runs but by no means the fit is loose or constantly get that niggly feeling they gonna drop out. I think your issue with the liberty 4 is probably the stem design. Earbuds with a stem are probably the worst kind in terms of fit for workouts.Hey thanks for the suggestion.. do they get loose upon running? I have an in ear liberty 4 but it will loosen up during runs and I have to keep pushing back in. Or does the redmi ones sit much deeper in the ears?
Thanks I've just bought the redmi on shoppeeI do have to adjust the redmi buds once or twice during my runs but by no means the fit is loose or constantly get that niggly feeling they gonna drop out. I think your issue with the liberty 4 is probably the stem design. Earbuds with a stem are probably the worst kind in terms of fit for workouts.
Alternatively, can consider the Samsung Galaxy Buds FE if you can still find sellers for it. These come with wing tips which are supposed to make the fit more snug and let the buds stay in your ears more securely.
Review: https://www.scarbir.com/tws/samsung-galaxy-buds-fe-review
Cant see what u bought
Now white around $73Thanks man. The white one is slightly more expensive than the black one. Got it @ $82, still a pretty good deal
This one
Tiagong sound quality lost to 4nc
But anc won 4nc i think.I think the apps n there's a lot of adjustments is really great n also the display on the casing.
