Oppo Find N5
garychengjw
Hey everyone! First-time foldable phone owner here. I’ve been taking good care of my N5’s main screen and haven’t been opening it too frequently. Earlier today, I noticed a dent on the main screen that wasn’t there before. Is this normal, or should I be concerned and take it to a service center? TIA for your answers.
Doesn't look normal. Mine don't have that "indentation" as circle.
eddy0505
Feel slight dent and when lights reflecting at it, I can see it clearly.
Was it there when you first got it? Else I suspect you could have knocked Ur inner screen against something hard at a certain angle. Tho you have that one year screen warranty to replace it still.
RaebRalop
but need pay $99 or something...if under 7 or 14 days i suggest go back to oppo and ask better.
Ecider
Singtel buyers of N5.
dont forget to check your email and claim ur X3i
mailer is out now.
tkte_85
how to contact singtel about the delivery of the oppo pen ah, its set to send to my workplace after office hours...
hydez_w
Definitely not, I have not dropped anything on to the screen...
I will go down to the service centre and ask them about it ..
Amuroraysg
how come singtel send business address after work hours.. usually they will now i mean singpost.
RaebRalop
This performance mode....doesn't like eat up much battery compare to balance.
Would had it it on 24/7 if not for that constant irritating icon on the top ?
Willteo25
Dear All, finally joined the dark side from iOS to Android with the Find N5 but I was not able to transfer my WhatsApp chats from my iPhone 15 Pro Max to the N5 using the initial setup method. Saw that only 12GB of data were copied out of the 52GB. Appreciate any kind advice from gurus here. TIA.
Ray1976
Saw you selling your phone over this WA messages unable to be transferred. There are tools that can do that.
Amuroraysg
my case come le.. full protection in silver.. but still kinda slippery.. don't the same grip like spigen ultra hybrid... back panel is silver.. i thought is transparent a bit let down.. fitting and hinge cover are good.. still thin. and got magsafe..
GeSteSoh
Got pic... got link?
GeSteSoh
Your whatsapp chats in the settings, should have a backup account into the cloud or google drive. Just ensure that is it fully backed up just before you restore into your new device.
