lenseview
- Dec 4, 2010
You didnt port in during current promo event how to get?strange how come I don't have, how to apply the credit?
i think eight is getting slower and cant even surf sometimewhat is the main reason to port out?
Definitely zym, regretted the switch to eight.During peak hour, eight or zym better?
If not happy, feel free to port out. That's the good thing about the number portability system that we have; consumers have a choice from a wide variety of MNOs and MVNOs.Definitely zym, regretted the switch to eight.
Eight doesn't do transfer of ownership. If you try to port in a number that doesn't belong to you, the port in will fail.
Option 1 just means that your family member who owns the number with your donor telco does the port in for you on Eight; it means he/she will still own the number with Eight.But under eight mobile website FAQ section, I found the below information. Note Option 1. So now I'm a bit confused
https://www.eight.com.sg/faq-port-in
- What can I do if my mobile number is not registered under my own Name and NRIC?
- Don’t worry! There are always ways! Thank you for considering us and we are keen to having you on our network!
- Option 1: You can ask your family members that registered your current mobile plan to conduct the port-in process for you.
- Option 2: You can ask your current provider to do a Transfer of Ownership to your own name and NRIC. After that, you can sign up for eight!
I also know, just that I have to use up the credits first...If not happy, feel free to port out. That's the good thing about the number portability system that we have; consumers have a choice from a wide variety of MNOs and MVNOs.
the option 1 is saying ur parent help u port in without transfer ownership. the line still under their name.But under eight mobile website FAQ section, I found the below information. Note Option 1. So now I'm a bit confused
Another way is to port to Vivifi or Zero1 first, they can settle the transfer of ownership for free(go research on their website). Fulfil their min period then port to eight.But under eight mobile website FAQ section, I found the below information. Note Option 1. So now I'm a bit confused
I have the same issue, just ported out.Eight mrt under tunnel cannot surf web at all bishan to orchard. Anyone having same issues?
Cannot receive or send sms.Can the simba esim data only $5 plan receive sms?
Thanks
Thanks, same for the physical sim too? I just want something cheap to receive otp.Cannot receive or send sms.
Yes, cannot receive sms.Thanks, same for the physical sim too? I just want something cheap to receive otp.
Thanks!Yes, cannot receive sms.
Any idea when does the port in promo end?It should credit to your account a few days after you successfully port in to eight.
Put into a mifi and used in Malaysia for a month. Didn’t notice any throttling. Maybe my usage was light. Less than 100gb.Is Eight OK for 4G router?
I'm not getting fibre internet for new home, so wondering whether there is throttling. A resident feedback that Giga Starhub is OK at the new place.
