OnePlus 13 series
masashi
Mister Mobile sells the official sandstone case for 13R for $18. Many outlets islandwide, can WhatsApp them to see which outlets have ready stock before heading down.
They don't have stocks for this anymore.. it's ok got a temporary one for free for the time being
1c3_5n0w
woah, how did you get a free case?
EDIT: nvm just saw that you used CDC.
was the case OOS at every mister mobile outlet?
masashi
Only got the black one.. maybe I'll get the silicon protector from lite mobile tomorrow
Veloso
I bought this clear casing off OP store on Shopee that time, quite decent for use/tahan for a while, while waiting for other cases to come. Saw a few TGSP on TB having reviews that say won't affect fingerprint and don't need UV glue, ordered but still waiting for arrival. :LOL:
1c3_5n0w
While deciding between purchasing the 13 and 13R, I was also trying to find good, non-UV TGSP for the 13.
I saw that those which didn't need UV glue had the black borders at the sides.
Do you know if yours has those black borders? If they don't, could you provide the link?
Mclairs83
anyone knows if OnePlus on android auto support whatsapp call already?
One can test by trying calling the person when connected on android auto. if the screen doesn't appear anything, that means its not supported yet.
Veloso
Haha. Same thinking! Was searching high and low for without black border ones, sadly couldn't find any. Then those reviews also mentioned border very minimal only, never 'eat' into the screen at all or won't notice that it did kind. I'll try it out first, if really as reviewed I will share, if not cin cai share tio f. Lol.
1c3_5n0w
Notebookcheck Review for those interested.
In summary, the battery life is good, better than OP13 in the Wifi and H.264 video playback tests.
But the 8 Gen 3 gets throttled really hard in the OP13R and leaves a lot to be desired in the sustained performance realm.
Something notable would be the average and max. idle drain of the 13R compared to other 8 Gen 3 smartphones; the 13R's idle consumption is 38% and 32% higher respectively. I'd wager the battery could be stretched a little more if this idle drain is optimised.
masashi
Took them around 5 days to get it delivered... A little too late but at least I won't have to remind myself of the dent and scratch till the end of time 😔
masashi
For the price I've paid, I think it's still worth it overall I guess:s34:
