Is there below 40$ stable PSU
Phen8210
Tier C is ok for light usage and normal usage, D and E best to avoid.
Heavy or spikey workload such as virtualization, rendering, or gaming better get B and above for better protection and overloading headroom, overall better components.
The_King
Hi, if I have a old system without Psu, is there stable/Oem PSU available in Singapore/taobao or is my best option is to look for second hand on carousel?
me got a corsair hx620watt, free if you want. keep in store room for 2yr liao, not sure if it still working
but i dont have the cable
nabil996
I still using Cooler Master V850 like super old PSU more then the warranty period more than 5 years
86technie
This? No problem so long it is working properly not giving you any issues.
86technie
Yes. Without the new things. It is depending on the batch one of my friend buy from Cooler Master and they face issue.
Batch Issue? Not that I know of.
MVE series especially not V2 range some model have strange issues.
Especially during gaming it will just shutdown or switch off.
V series and GM are OK in my opinion.
I still have a old CM GM here still working no issues.
liewhl
Apprectice your offer,my intentiion is just to find out if there is any hidden options than the FSP bronse i found in sim lim to grow my knowledge.
86technie
Hidden option? Cheapest is FSP next will be VIOS which some shop may recommend for cheap psu.
Icute, VIOS best to avoid cuz risk of exploding is very high.
nabil996
For me without 80 PLUS Bronze minimum i would not buy on my opinion. The higher grade you go the more money you spend but in return the power saving will come to keep in mind
liewhl
what i mean is like lesser known. Actually there thiis brand call 玄武电源 seem to be very popular oversea.
86technie
From Taobao psu usually are not safe.
If you want to try is up to you.
Risk of damaging the pc is very high.
Cuz I have a few PC with Taobao psu blow up at my side.
liewhl
wa, you bought them for daily use? they look like this? i see on tb they look differnet and they got bronze too. However, i dunno is the bronze real or fake one.
86technie
User PC not mine, some buy from Taobao got issue so send over for checking.
Doesn't look legit at all.
Up to you if you just want cheap PSU, can ask for this PSU from shops like Bizgram.
Think is around $30+, how long it will last before it blows only you will know.
liewhl
nabil996
You can give a try on Superflower or FSP PSU that is the cheapest that i know off but the price is abit out of 40 buck price range
deepblue_82
superflower not that cheap.. but FSP is a okok psu.. but dont know if u still can find 450w or 400w anot...
but i dont think is 40$
nabil996
Because superflower is an OEM PSU for most common computers brand eg EVGA, and FSP for workstation computer and sometime sever. Plus they have basic 80+ so you pay more for good then some other brand dont have that and they can boom ur part.
Phen8210
My Superflower Leadex II has been running strong for 7 years with daily use, proving itself to be in a league of its own when it comes to reliability, even compared to other premium brands that have strong marketing.
The PSU wasn’t even that expensive considering its performance and longevity. I paid just over $100 for it.
A decade ago, I learned that lesson firsthand after purchasing 3x FSP Aurum Gold units on separate occasions.
All of them developed issues or instabilities within 6 months to 3 years. These were installed in PCs that are used daily, not just idling or running light workloads on a home mini server. This was a real-world, long-term reliability test.
I know some people like to bring up servers as a counterargument, but let’s be real, many of these so called servers are merely "self serving home servers" that is idle literally 90% of the time and only occasionally handling small tasks. That’s nowhere near a valid comparison. Besides, server-grade components and consumer-grade PSUs are built to entirely different standards.
That experience taught me to avoid budget and mid-tier PSUs entirely if you really are in for the long run, plus superflower low failure rate is not a fluke from someone having worked in RMA.
