POCO X6 series
vampire29
hi, would like to check... anyone got issue when listen WA voice msg the screen wont turn black n play in speaker mode? any solution?
Kitaro9202
Just purchase x6pro to replace my Samsung s20fe
Using as a dispatch phone the Samsung s20fe have reception issue .
Took more den 2 min to get the signal back after exiting condo carpark or normal lift
kazuki666
My Poco X6 Pro just received off the air firmware update to 2.0.100.0
I feel there are some significant changes in overall feel. Before this update, I will lose network, and thumb print security is no sensitive to detect. Both are smooth now. There seems slightly less lag now too.
carboy00
yup could feel the difference in fluidity between initial HyperOS 2 build and this new HyperOS 2.1 update, much improved.
Read HWZ Forum Rules!
kazuki666
Does anyone know if Poco X6 Pro has function to hide or lock folder of apps in the home screen?
dnsfpl
good buy?
dnsfpl
the base price now is $299, even if i add the new user max $30 discount voucher, it will only be $269, am i missing out any other vouchers?
mine base was $279
12% + $20 off
wait for 4.4 ba
pohu
Wonder if you guys update your OS when prompted? I am currently using POCO X6 5G.
My main concern is if my phone's free space will be reduced drastically after the upgrading?
image uploading sites
pohu
HyperOS on 2.0.x already.
yours still on 1.0.x :unsure:
Just did a double upgrading of my OS to HyperOS 2.0 that gave me fright when the screen freeze and I had to google on how to reboot my phone
