- Jul 5, 2001
The original N3 charger is legit, it's the tester (or how u tested was wrong). It may display wrong supervooc wattage in the lock screen on some cases, like my case with my old 65w c-c supervooc displaying as 100w on my op13 whereas my spare 80w a-c charger just shows supervooc (coz it's supposed to just show supervooc when it's the wrong wattage/below the phone's wattage). Another way u can see the charge is key *#899# on your dialpad, similar to checking the IMEI number, then under manual test, then device debugging, then charge testi also low key felt the same. i saw the fnb58 reporting slightly under amp than another usb tester i had.
now that you mentioned it, i went to take a look at charger and they are according to what you indicated. however the bloody charge never seems to go beyond more than 3amp. wonder if the original charger that came with N3 was a bluff.
thanks i saw this too online too. need to ownself convert the miliamps to determine the true amp / wattThe original N3 charger is legit, it's the tester (or how u tested was wrong). It may display wrong supervooc wattage in the lock screen on some cases, like my case with my old 65w c-c supervooc displaying as 100w on my op13 whereas my spare 80w a-c charger just shows supervooc (coz it's supposed to just show supervooc when it's the wrong wattage/below the phone's wattage). Another way u can see the charge is key *#899# on your dialpad, similar to checking the IMEI number, then under manual test, then device debugging, then charge test
I meant the default email app on the N5What's the native oppo email client?
Oh, I dont bother on ECG and sleep apnea...as the watch very fast running out battery, so wear it for sleep the next day battery too less for working routine..haha..from watch no issue, it's if i need to use paywave from phone. anyway i just realize the problem is with the phone. i had to turn off NFC and on again then can paywave. no issues with opening google wallet, open app already but payment terminal cant detect phone
thank you!
i sideload to get the rest of the function to work with oppo, for eg ECG and sleep apnea.
yes bro,![]()
Yes, what's the default email app for N5? For now i can only see gmail app and it is cmi. Using outlook instead.I meant the default email app on the N5
I see it's a pre installed app call Edison mail+.Yes, what's the default email app for N5? For now i can only see gmail app and it is cmi. Using outlook instead.
Not selling the phone. Appreciate any advice on how to transfer my 52GB of WhatsApp data from my iPhone 15 Pro Max to the N5 as the native method using the N5 transfer is not working. Most of the chats are still missing when I open WA on the N5 after the transfer. Thanks.Saw you selling your phone over this WA messages unable to be transferred. There are tools that can do that.
Does this work for 52GB of WA data?Your whatsapp chats in the settings, should have a backup account into the cloud or google drive. Just ensure that is it fully backed up just before you restore into your new device.
You can double tap volume to launch camera.Any lobang for cheapest oppo n5 set ?
Also is there a way to double tap power button to launch camera like Samsung phones ?
it should but will take a long restore time most likelyDoes this work for 52GB of WA data?
Interesting. I do not have this preinstalled in my phone.I see it's a pre installed app call Edison mail+.
Sorry for the confusion. Maybe I might have accidentally installedpre installed with Edison Mail+ ? is this for N5 Singapore set? mine doesn't come with it.
If on youtube streaming account, youtube music is preinstalled and plays well on android auto as well.Other than Spotify, any media players that work well with N5 as seems like no pre installed app for music
