lalalalalala
- Dec 25, 2005
power adapter can just buy online or from shop, make sure voltage same with maybe +0.5 tolerance. for current any rating equal or higher than the original adapter should workOkay lah, my Archer C7 how long liao got 10 years already? Still wifi 5.
Routers don't spoil a lot unless pathologically badly designed like a certain brand I once worked for. The highest chance to spoil is the power supply and even then only if you cheap out on it. My ONT power adapter spoil twice.
