My Chromebooks' power adaptor from US have dual voltage. So sure should be no issuesI wanted to buy this Samsung Chromebook plus V2 2in1. She likes this since got pen and touchscreen.
Link : Samsung Chromebook V2 2-in-1
This is in Amazon US.
Does it come with 220V or need some transformer all ?
This is quite an old model, suggest to reconsiderI wanted to buy this Samsung Chromebook plus V2 2in1. She likes this since got pen and touchscreen.
Oh any new models to recommend with touchscreen and stylus support if possibleThis is quite an old model, suggest to reconsider
i can think of lenovo chromebook duetOh any new models to recommend with touchscreen and stylus support if possible
https://www.amazon.com/gp/aw/d/B0D33NC672Any good for value chromebooks? Don't need an expensive one, just need a dedicated computer for my crypto transactions.
Preferably Lenovo since my laptop has been still working after all these years.
Thanks!
If using for just web browsing, edmw, Youtube and some emailing... would this be good enough?
yesIf using for just web browsing, edmw, Youtube and some emailing... would this be good enough?
Thanks for the tips...yes
FYI just in case, not sure if u used chrome os before, it is different from windows, cannot install exe apps
mostly use browser, if need to install apps, can only install linux apps, and that is not turned on by default
can also consider newer chrome os models, did a quick search, this one also $200+, but note, is 14-inch screen, heavier
https://www.amazon.com/ASUS-Chromebook-Anti-Glare-1366x768-CM1402CM2A-DS44/dp/B0CJS1399P
So I was looking around Amazon for chromebooks when I saw an Asus laptop with Win 11s home and Intel N6000 4gb ram and 64gb eMMC with 64gb microSD card going for $244... I understand that Win 11s home takes up much less memory space than the regular Win 11/Pro and restricts d/l of programs and apps to only Microsoft ones and when u do d/l stuff, it would usually be saved on Microsoft OneDrive that's why u dun need much memory space or hard disk space on the laptop and it still can run and operate smoothly... would that be correct?yes
maybe better to answer Windows question in a Windows threadSo I was looking around Amazon for chromebooks when I saw an Asus laptop with Win 11s home and Intel N6000 4gb ram and 64gb eMMC with 64gb microSD card going for $244... I understand that Win 11s home takes up much less memory space than the regular Win 11/Pro and restricts d/l of programs and apps to only Microsoft ones and when u do d/l stuff, it would usually be saved on Microsoft OneDrive that's why u dun need much memory space or hard disk space on the laptop and it still can run and operate smoothly... would that be correct?
Oh I forgot to add to what I said earlier... the reason I brought up about the windows topic was because I was likening the Asus Windows laptop to a chromebook in that the Win 11 Home OS will also only take up little memory space compared to the regular win 11/Pro and d/l of programs is restricted to only microsoft ones (thus limiting dwonloads) and anything u d/l will usually be saved to OneDrivemaybe better to answer Windows question in a Windows thread
anyway, personally do not recommend running windows in s mode
first thing for most people when buying a s mode device is to turn it off
64gb storage is going to be very tight, due to windows updates in future
can consider, but suggest to store files in separate drive, e.g. micro-sd [if there is a slot on device] or small thumbdrive
expect it to run slower compared to the equivalent chromebook also
Ya I noticed laptops sold on/sold by Amazon Germany are cheaper but have to take note that some are with "QWERTZ" keyboard layout which is for German or some foreign language wan like this one...$206
Note, from Amazon Germany, keyboard layout may be different
https://www.amazon.sg/ASUS-Chromebook-CM1402CM2A-Laptop-Inch/dp/B0BRYYRC58
