Honor X9C -
flohua
Does anyone use a powerbank for x9c. Any recommend powerbank? Had 2 powerbank for my old phone and it works well, not heated up. But when i plug to my new x9c. My powerbank get heated up fast and furious and the % very fast went low. Im using a 10k mah.
caterham7
x9c supprts 66w charging, but likely using proprietary tech
Can consider basic model from xiaomi
$14.50
https://www.mi.com/sg/product/xiaomi-power-bank-10000mah-22w-lite/
Remember to collect coupons before checking out
Mrsthio
Hi anyone faces problem with Chrome app keep closing? Tried the method suggested in youtube however doesnt work. Thanks
8-lane
U mean X9c has a known problem of Chrome app keep closing?
rharish_21
Magic OS 9 based on Android 15 is available for X9C. You can trigger download using the Try Out version option.
wyverns14
Anyone with a X9C can help to check if playstore can download "Libre Freestyle"?
Need to buy 1 for my FIL as he is diabetic n to monitor his blood sugar. (Need phone with NFC)
My spare phone poco C71 does not have NFC, and also cannot find the app as well. TIA.
shager
I have the x9c that is my spare phone.
This app is from Abbott? It allows me to download and run all the way to account creation without issue. I did not go beyond this but seems to run fine.
wyverns14
Thank you!
Just ordered from Lazada.. $369 with free ear buds.
DesilDesil
Just got a set from challenger
Very disappointing model, the specs also not great, 6600mah behaving like 5000mah xiaomi and xiaomi themselves aren't battery king
Turns out alot type-C earpiece can't use (not an issue with my other Sharp, Xiaomi, Poco, Realme, Samsung phones at home) . 3 type-C earpiece that i tried all don't work only on this Honor X9C
Bricked my entire purchase as well as 2 type-C earpiece
Summore challenger return policy is absolute garbage
Scammed big time, legacy electronics store to scam old folks
Next time stick with shopee
8-lane
How about selling it on Caro?
i1magic
So you are not going to use this phone just because your USB-C earpiece can't work on this?
LawStr
The Honor tough series is back with X9c.
Price looks fair for what you get. The X9c focuses on durability, so it makes sense if you want a phone that can handle drops and daily wear. The free gifts add some value. If camera performance or software support matters a lot to you, compare with Samsung A or Pixel options in the same range. Otherwise this is a solid pick for everyday use.
