Oppo Find N5
Peanut15
I miss how Samsung manages the notification, the photo gallery folder arrangement. Basically oneui.
Other than that n5 is all good ..
the tent mode very hard to use to watch video. (you need to turn on screen rotation, then shake the phone to make sure it register the landscape mode, then double tap front screen).
The inverted tent mode doesnt even work.
It was rather easy to use on samsung fold 5
eddy0505
When unfolded go to camera> switch to selfie mode using main camera> go back front screen close the camera and you can use it for both tent and invert tent mode. Need to be creative to maximise foldable utilities and features.
onceheaven
I used to think the same way. But if you just half close it, set it down on the table, it'll turn on tent mode automatically
fool1988
How about the camera and NFC and android auto ? All of which is use so regularly. Thx in advance !
Camera....so far ok la...use for portrait only...tele and uw weak a bitm..
Nfc work fine with google wallet ...
Android auto work well with both wireless and wired...
kenner
I intend to get the niklin also...but afraid it will be too bulky and heavy...I used that on s23u and it quite heavy
The Lazada one came and I'm using it now. Grip feels better than the original case that came out of the box. Except the hinge protector pushes on my additional pasted tempered glass while opening the inner screen, not sure if one day it'll lift my tempered glass. Will use this for the time being while waiting for the nillkin one.
BaByAsheZ
Anyone having issue with typing on Google keyboard not registered toward the bottom ( Button Across the spacebar )when folded
alanysy
Can the video mode ratio be set to Fullscreen? I don't see the option. Camera mode can set to 11:10 but not video mode
Gaddy23
I didn't get my pen or any notification then contacted starhub who told me it's while stocks last. Wth. Then what's the point of the pre order promo when you can't even fulfill it. Might as well I wait and get it now (the freebies now are even better)
sallybee
I am very impressed with the hinge on this 1. have bought the black one to use after selling away my OnePlus 13 512gb. however the camera isn't as good as the one on oppo x8 pro
sallybee
will try to helpout with information on this phone as have change to this after the disastrous Oneplus13
