patching faux leather peeling method
articland05
my ear cushion faux leather is peeling liao everytime use my ear become black black
so moi use white glue and tea bag filters to cut and patch the peeling areas...seems notch bad.
left is when the glue is wet
right is after dry...the glue less visible
chiu can consider this method if hab this issue also
artncraft
The glue may contain toxic chemicals that your skin can absorb.
articland05
AI say ok leh...cos is skool type of white glue
Most common household white glues, like Elmer's, are generally considered non-toxic and safe for use in crafts and school projects, especially for children.
artncraft
Don't trust AI so much.
Companies will always state their products are safe on their websites. AI will pick up these information and present it to you.
Glues are polymers with additives that adjust their bonding strength and speed with other materials. These can also break down over time and release chemicals that your skin will pick up.
articland05
Companies will always state their products are safe on their websites. AI will pick up these information and present this information to you.
hokay bro :frown:
justln
if got money who wanna be beggar :frown:
This kind of money can save meh?
If your ear cushion is peeling, means it has accumulated how many months of your body oil? I see also know it smells.
Just pay the $10 or so to buy from Shopee. Later your skin allergic or pimple, spend even more time and money on medicine.
deathan9el
Honorary Mentor
honestly, me wouldn't even try to salvage or repair w/ whatever method possible
dun even say glue :s22:
either me stop using it altogether or get a replacement cups, mentioned by others before this thread
but really, even for the latter me dunno how to fix it to replace :s22:
might as well get a new pair
* bought a JBL headphones last year but w/ synthetic leather cups instead
even tho' me kinda dislike wearing headphones :s22:
articland05
actually is the opposite for moi...
the peeling cos moi clean too often until peel :frown:
