MARI invest
white_prince
It is better to track the daily NAV change via their website, it is usually updated by the end of the day after 6pm.
https://www.lionglobalinvestors.com/en/fund.html?officialNav=OFBF
You should also try to understand the product more, by last Friday, you can already know the return you get today is zero. Because weekend is "non-trading" so the NAV does not change, what you get on Monday is actually the NAV difference from last Thursday to Friday.
It is better to look at the returns on a longer term basis, or at least on a monthly basis rather than focus on short term fluctuations. For the current situation, usually when the short term returns is on the higher side of 3%, it is not sustainable for this type of product to go higher, so it will pull back a bit and go sideways, eventually it will just average out.
The link you sent is very helpful, somedays really dont have positive “+” matches with $0 interest.
geographic
This week the return is $0.0004 (Mon to Fri). Fund Manager is 😴. Lowest so far as per what I can recall. If this persist, the return will be lower than the Mari Bank rate of 2.28% come Apr.
alex22
This week the return is 0.0004 (Mon to Fri). Fund Manager is 😴. Lowest so far as per what I can recall. If this persist, the return will be lower than the Mari Bank rate of 2.28% come Apr.
The expected is sideways one, house wins
jayvenkoh
Anyone tried to sell all for Mari invest income? If sell all, will u get the same amount of money as stated on market value on the app?
