Zero1 Mobile discussion thread
uncle_josh
Already selected lte only, poco f1 no 5g haha. Zero1 doesn't work but eight got volte so it's not the phone setting imo.
Poco phone, dial *#*#86583#*#* in the phone's dialer app, which will display a message indicating the check is disabled, enabling VoLTE.
chaiscool
Yeah alr did that but somehow moi poco f1 volte doesn't work with zero1 $7 plan but ok with eight. Was wondering anyone got similar issue
JAYSCS
Is it the dial to disable volte carrier check? If so, then yes.
So you all on zero1 $7 plan can use volte?
SingTel is not giving all its bandwidth to all its network subsidiaries and partners, my 2016 Samsung Tab J cannot detect LTE/4G for ST Prepaid, Zero1 and Heya but SH, M1 and Simba 4G data network can be used. But if you are only facing VoLTE problem only and not 4G data problem, then it could be SingTel is not registering F1 as VoLTE device.
chaiscool
Yeah was not expecting it to be this complicated. Luckily I stumbled upon this, was contemplating on getting a new phone.
lexisnexus
Not sure if anyone has problems activating iMessage and FaceTime via eSIM?
Ported into Zero1 on last Friday, the iMessage/FaceTime function always told me the number is "verifying", and I need to manually input my phone number into "Mobile Service" in the app settings, or the "My number" field will always be blank.
I also contacted the support, they told me they have reset my mobile network profile, however, still doesn't work.
May 08 update: Seems like my number can't send Global SMS (even Global SMS is enabled), thus iMessage/FaceTime can't be activated. Support team is checking this.
Jun 16 update: They finally fixed it…
jinsatkilife
anyone know if u sign up for $7 plan with physical sim, can you upgrade to esim for free later?
ps if this has been asked
Arandalo
AvatarViper
why who anyone choose their Jumbo Go Prime @ $12.70? Same 200GB as their Starter Prime @ $7.06 ma.
somemore Jumbo Go Prime no free roaming. what the heck...
