highsulphur
- Aug 16, 2011
Does anyone know how to activate ROTW data roaming for APAC countries? Or die die must use APAC data roaming pack?
Hi all, remember this promo? I just realized that I have a gifted number and its sim card with me still unactivated. I can see it in my giga account. Any idea if I activated it now is the free 4 months subscription still applicable? Thank you. I've reread the promo TnC don't see any that says line must be activated by xx date.Here u go.
Hi hi!
Here’s a special surprise from me to you: use promo code <gigaX3uF> to enjoy $10 plan FREE for 4 months
• 10GB/mth with free Rollover Data
• 300 mins, 300 SMS
Plan reverts to usual price of $10.10 after 4 months.
How to use gift code:
1. Download the giga app, select $10 plan
2. Enter gift code and check out at $0
3. Receive giga SIM card and activate
Download the giga app to sign up with Gift Code <gigaX3uF>, valid till 31 Aug 2023. https://tinyurl.com/gigafeelsgood
Like that only by trying that you will find out.Hi all, remember this promo? I just realized that I have a gifted number and its sim card with me still unactivated. I can see it in my giga account. Any idea if I activated it now is the free 4 months subscription still applicable? Thank you. I've reread the promo TnC don't see any that says line must be activated by xx date.
Not IOS user hereVolte is automatically enabled on all (latest) iphone models, right?
Searched high and low for the VoLTE option in settings and can’t find.
I was unable to make outgoing calls with my android phone voWIFI, could be a similar case to yours.Anyone unable to make outgoing calls with Giga?
They also have a written guideJust “Giga” for APN field and other fields left EMPTY, like what they mentioned on their YouTube guide?
I don't understand the link here. Enhanced network but is NSA?Received email from giga on enhanced network.
Realized that Giga 5g now supports NSA network.
Shared the email here to see?Received email from giga on enhanced network.
I think they mean this email:Shared the email here to see?
Could you please double-check that your APN (Access Point Name) is set to 'GIGA' and not 'SHWAP'?Not sure anyone encounter dropped 4G network signal past few months... it is like every hour signal drops. Anyway I going switch to another MVNO
Double-check my APN is set as "giga".Could you please double-check that your APN (Access Point Name) is set to 'GIGA' and not 'SHWAP'?
Although 'SHWAP' is known to work with GIGA SIM cards, I've noticed that it can occasionally cause data issues if configured to 'SHWAP' instead of 'GIGA'.
By the way, there's also an issue I've encountered before while using GIGA.
I twice lose network connection and data in specific areas. The data issue typically resolves itself once I travel to another MRT station or location. This has also happened to other friends.
So it is no network or you have 4G only?just got my honor 200 smart 5g hp , spent the past 30 mins registering to giga 4g . no matter automatic or manually registering also cannot do so. anyone experienced this before? it can detect the giga apn but it's showing no network
