MARI invest
white_prince
It is better to track the daily NAV change via their website, it is usually updated by the end of the day after 6pm.
https://www.lionglobalinvestors.com/en/fund.html?officialNav=OFBF
You should also try to understand the product more, by last Friday, you can already know the return you get today is zero. Because weekend is "non-trading" so the NAV does not change, what you get on Monday is actually the NAV difference from last Thursday to Friday.
It is better to look at the returns on a longer term basis, or at least on a monthly basis rather than focus on short term fluctuations. For the current situation, usually when the short term returns is on the higher side of 3%, it is not sustainable for this type of product to go higher, so it will pull back a bit and go sideways, eventually it will just average out.
The link you sent is very helpful, somedays really dont have positive “+” matches with $0 interest.
geographic
This week the return is $0.0004 (Mon to Fri). Fund Manager is 😴. Lowest so far as per what I can recall. If this persist, the return will be lower than the Mari Bank rate of 2.28% come Apr.
alex22
This week the return is 0.0004 (Mon to Fri). Fund Manager is 😴. Lowest so far as per what I can recall. If this persist, the return will be lower than the Mari Bank rate of 2.28% come Apr.
The expected is sideways one, house wins
white_prince
PH will be included in tomorrow’s payout?
Sat, Sun and Mon?
Wed will be Tue and Wed?
jayvenkoh
Anyone tried to sell all for Mari invest income? If sell all, will u get the same amount of money as stated on market value on the app?
