[Software Update] iOS 18.7.2 is out!
kashix
How’s the Apple intelligence? Is it battery draining? My iPhone 16 Pro Max like not as lasting as before, a bit worried to enable AI, if battery is going to be worse.
coldspot
Oh 18.4 is here? Does it comes with apple intelligence (Singapore) ?
RaebRalop
Is it possible to add flight itinerary to apple calender via apple ai , digging whole morning till.
oric1
Using DeepSeek R1.
To add a flight itinerary to Apple Calendar using Apple's AI features, you can leverage Siri or automatic event detection in the Mail app. Here’s a concise guide:
Method 1: Using Siri (Apple’s AI Voice Assistant)
  1. Activate Siri:
    • Say “Hey Siri” or hold the Home/Side button.
  2. Command Example:
    • “Add a flight to my calendar departing from [origin, e.g., JFK] to [destination, e.g., LAX] on [date] at [time].”
  3. Confirmation:
    • Siri creates the event. Verify details in Calendar.
Method 2: Automatic Detection via Mail App (AI-Powered Parsing)
  1. Open the Flight Confirmation Email:
    • Ensure the email is in the Apple Mail app.
  2. Detect Event Details:
    • Dates/times/flight numbers are highlighted.
  3. Add to Calendar:
    • Tap the detected time/date → Select “Create Event” → Adjust details if needed → Save.
Additional Tips
  • .ics Attachments: Some airlines send calendar files (.ics). Tap the attachment to auto-add the event.
  • Siri Suggestions: Swipe right on the Home Screen or check Calendar for AI-generated suggestions based on emails/messages.
  • Wallet Integration: If your boarding pass is in Wallet, enable “Show on Calendar” (Settings → Calendar → Accounts → iCloud → Enable “Events & Shared Calendars”).
Troubleshooting
  • Ensure iOS/macOS is updated.
  • Check email formatting if automatic detection fails (manual entry via Calendar’s “+” button may be needed).
These methods use Apple’s AI (Siri/NLP) to streamline adding flight details, minimizing manual input.
zorrus
Moderator
Moderator
Anyone facing AirTags location not syncing after iOS 18.4 upgrade? I am using iPhone 16 pro max
leongws
iOS 18.4 iPhone 16 PM. Encountered apps auto refreshing. Example safari tab with hwz will auto refresh in background after the phone was left idling. How I know because the tab background for hwz display will be “light” instead of “dark” mode. After I refresh the tab then it will be dark mode.
Straits time E paper also auto refresh to main page from the last date and page of e paper I read. Because of this I kept needing to select the date and the pages again to resume for where I left off.
Default mail app also auto push new email as I can see the numbers at the top right of mail app which indicates new email when the settings are manual instead of push all the while.
***background app refresh settings all the while off mode
Remember something like this happen before in one of the iOS update thought cannot remember which one.
These resulted in my phone to feel hot and battery drain faster compared to before updating to iOS 18.4 as it kept refreshing on background. Wonder anyone encounter similar as well.
Screenshot of safari tab as below. The light mode is the tab auto refresh to like default which shows I am log out and dark is the mode that I used. After a while the dark mode tab will also turn light mode if not using the phone. After I click into the light mode tab, it will auto refresh to dark mode and will be logged in.
