Storage upgrade advise
Lit3s
Hi guys, need some advise. My old 250gb SSD seems to be failing soon, thinking to get a nvme which seems to be the only option. My board is an Asrock B460 Steel Legend which i understand to run with gen 3 nvme. Will the gen 4 be compatible to run? For eg. Samsung EVo 990 or WD SN850X. I know it won't get speed of gen 4 but makes no sense to get a used gen 3. Looking at either a 1 or 2 TB to run OS.
Also which 8-10TB hdd is reliable nowadays? WD blue seems to be unreliable. My 4TB green of 8 years is still in great health compared to my blue which only lasted 5 years and went dead
Thank you!
xonix
YES.
Thank you!
Buy NAS HDD
86technie
Thank you!
You can get Samsung 980 (non-pro) gen 3 or Samsung 970 EVO Plus if you can find one.
Samsung EVo 990 plus or Lexar NM790 gen 4.
But since this mobo only support gen 3 so these SSD won't be able to tap
on it's full bandwidth of up to 7000mb/s.
You can get but you won't tap on the full speed of the SSD.
8TB onwards HDD depend on the model, avoid blue or Seagate barracuda line.
Try to get at least NAS grade like Seagate Ironwolf will be better
Higher price but NAS grade HDD will have better endurance than consumer grade.
Lit3s
Thank you for the advise. I’ve looked around, seems buying the gen4 seems more realistic. Used gen3 etc being priced so close to gen4, wonder why.
for storage, normal desktop can run those NAS hdd like normal? Trying to see which ones are more value to buy. Eg wondering to buy 2 x 6TB 3.5” or a single 10/12TB. Just worried if hdd dead everything gone
ragnarok95
Senior Moderator
Senior Moderator
You can easily find either Crucial T500 or WD 850X 1TB going for around S$105-110. Both good for OS drive.
Vanyel
No. P3 is QLC. I would much rather get Lexar nm710 for a slower and more reliable TLC drive. Probably cheaper too.
i think nvme ssd not that easy to uplorry ba?
so far i havent had any dying on me and i think i got like 7-8pcs all from different manufacturers lol
saw Crucial P3 Plus 4tb at $319, im tempted to get it myself
86technie
Vanyel
last dec i got was this for my elder boy
dun really think either of us will feel the difference between a higher or lower grade nvme ssd
its not really like a jump in performance from the sata to nvme
86technie
Actually there is different SSD use TLC or QLC.
https://www.purestorage.com/knowledge/qlc-vs-tlc.html
That China OEM SSD is cheap but risk of failure very high.
I got a couple keep bluescreen that I chunk it away.
For SSD try to get reliable brand, Crucial, Lexar, Samsung etc. Will be OK.
China brand like SP and etc. Don't get.
Vanyel
The SP i bought b4 2tb already, hence i wasnt worried about buying it again
And over amazon i not too worried about rma
and its still working ok til now
*knn last time $200 can buy 2TB x2 T_T
86technie
So long if you are using as data drive than ok.
OS drive is no like I shared it will bluescreen randomly.
-Synchronicity-
Ehh not really. It's all about the controller and flash.
For example, the infamous innogrit IG5236 controller which many decent ssd uses like:
1. Acer predator gm7000
2. Lexar nm800
3. Teamgroup t-force g70
4. Adata gammix s70
Most of them have complains about the SSD uplorry way before any of them even sniffed their MTBF and TBW rates. Some as early as just 1 hr into their usage.
If a ssd has good combo of their flash and controller, they might not even need cache to match against higher tier ssd with cache, case in point nm790 with 232 layer TLC YMTC nand and the super popular maxio MAP1602A controller - both the nand and controller china based products btw.
Btw the SP UD90 is one of the more popular budget SSD drives. Too bad locally the distro don't bring in that drive making the lexar nm710 much more attractive and competitive.
86technie
2. Lexar nm800
4. Adata gammix s70
If a ssd has good combo of their flash and controller, they might not even need cache to match against higher tier ssd with cache, case in point nm790 with 232 layer YMTC nand and the super popular maxio MAP1602A controller - both the nand and controller china based products btw.
You name some of the popular budget drive use by Aftershock.
Acer SSD is not sold locally that one only through online.
Usage also affects SSD wear and tear especially when you play online games which have lots of read and write.
Is best to get a reliable SSD.
I don't want to use Aftershock as an example but you already mention it. :s13:
-Synchronicity-
Of course the best is to get a reliable SSD. Honestly the best way is to view the specs like controller and flash used.
Oh and games read and write is considered miniscule.
ragnarok95
Senior Moderator
Senior Moderator
But the only trashing i more concerned over is pricing~
lol
How ex can a NVMe be now that you are concerned over pricing? A good NVMe with good controller goes a long way.
