Nowadays Tablet dun comes with 3.5mm audio jack??which usb c to Audio jack adaptor should I buy I wanna use for Samsung tablet?
So cheap... I got the SHP9500 and Fidelio X3.. but problem with SHP9500 is the freaking ear pads is bukeyi... too thin and my ears are literally touching the hard part of the headphone inside... feel uncomfortable...
this guy thought that he has ears with universal shape, and everybody must follow his ear shape.A Simplified Guide To IEM Silicone Eartips
https://www.audioreviews.org/guide-to-iem-silicone-eartips/
Work out nicely, did have some work to take off the old one... but found a video and then with the help of a long metal ruler to pry it open. I managed to install the new pads and wonderful my ears no longer touch the inside of the headphone. Awesome.So cheap... I got the SHP9500 and Fidelio X3.. but problem with SHP9500 is the freaking ear pads is bukeyi... too thin and my ears are literally touching the hard part of the headphone inside... feel uncomfortable...
Already ordered this ear pads hopefully will fix this issue.
can try moondrop chu ii and change to type-c cableany recommendations for wired earphones, type-C kind? 50-100 SGD range, for getting max quality on Tidal on handphone.
Somebody mentioned SAM Audio... they also selling on shopee but I think they have a physical storefront.Thanks a lot! Is the moondrop chu 2 having a condensation problem? How about size? Prefer a smaller sized IEM honestly. Any other suggestions besides chu 2, for me to test/compare? SG got any place to test these chinese IEMs?
The Chu, thr usb-c can detached ahcan try moondrop chu ii and change to type-c cable
btw, iem with 3.5mm that have detachable cable, can get type-c cable
moondrop chu is fixed cableThe Chu, thr usb-c can detached ah
so it comes with cable which connects to dsp then to phone's usb-cmoondrop chu is fixed cable
moondrop chu ii has detachable cables, meaning you can buy a cable to replace the original cable, one that has type-c connector instead of 3.5mm headphone jack
best is to check website and read the details
https://moondroplab.com/en/products/chu-ii
Here very much dead 1.Any good wireless earphones for jogging/running/exercise, with budget within $100? mostly listen spotify/Apple Music/podcast
we usually use this thread for wired headphonesAny good wireless earphones for jogging/running/exercise, with budget within $100? mostly listen spotify/Apple Music/podcast
