Sous vide takes time. 2hrs plus/minus. And a good steam oven is costly. You can do your steak in the air fryer too. Just get a temperature probe if you are particular about the temp of meat. And finish off searing in a sauce pan/w lid. It keeps much of the oil splatter within.nice,
what spices do you use? share share.
is your glass container air fryer la gourmet ? and if you want butter, rvs ntuc is cheap
me hunting for a steam oven i hear that steam oven can be use for sous vide. then i follow gugafood to sear the surface.
https://steamandbake.com/how-to-sous-vide-steak-in-a-steam-oven/
I'm using borosilicate glass containers and a decent sized air fryer bought off shopee. Preparing meal is easy.
Used to try out different spices and herbs from phoon huat. After a while, found out that salt is the best in elevating the taste of meat, fish and eggs.
it's really puzzling that only rvs ntuc have the discounted butter. But thanks for the heads up!
