Can only switch back after Ur $18 plan expireHi everyone. I’m currently on the $8 plan. Upcoming trip to Australia.
If I choose to upgrade to the $18 plan, am I able to downgrade to the $8 after my trip? How does it work?
I encountered same issue.I was in JB for the past 2 days, the data roaming with the two partners are quite unusable - encountered a lot of spots with weak 4G connections, and also spots where it is non-existent at all (only EDGE connection). The area around KSL seems to be the worst for some reason.
Don't think it's the fault of Eight, more like issues with the mobile infra there
You could do that. But if your phone supports eSIMs then you could simply get a separate, lower cost data eSIM for Australia. For example, Always Mobile is offering 10GB of data in Australia valid for 30 days for US$6 (a little under S$8). (Hint: On their Web site select USD.) In other words, you can get 2GB more data (a total of 12GB instead of 10GB) for less money.Hi everyone. I’m currently on the $8 plan. Upcoming trip to Australia.
https://www.eight.com.sg/faq-network-roaming-and-iddHi
Can I know which are the countries that I can call to SG, and receive calls from SG?
And how many minutes are included?
Thanks.
Same experience recently but don't think it is eight's fault.I was in JB for the past 2 days, the data roaming with the two partners are quite unusable - encountered a lot of spots with weak 4G connections, and also spots where it is non-existent at all (only EDGE connection). The area around KSL seems to be the worst for some reason.
Wa the speed jialat
Might be eight or starhub issue, I had no problem with Hotlink as 2nd sim which also uses Maxis network, so its definitely not due to poor signal etc. Same phone, same time, same place.Same experience recently but don't think it is eight's fault.
Was at the kopitiam in JB, my eight and my family member's redone both cannot receive internet (Maxis). Not sure if it is because both are based on Starhub?
Another member's eSIM bought online can work.
Funny part is my work phone Singtel, roaming on Maxis network can receive internet at the same location, so I on hotspot.
Was at Batam last week. Suprisingly connection there is better than my main line (GOMO). Getting full bars most of the time and able to stream youtube etc.Anyone tried the Indonesia roaming recently? Reliable?
Hi, your is $8 or $11.80 and above plan? Since $8 plan roaming data is not shared with SG.Was at Batam last week. Suprisingly connection there is better than my main line (GOMO). Getting full bars most of the time and able to stream youtube etc.
Mine is the $11.80. I would say connection is better in my case in Batam than in JB.Hi, your is $8 or $11.80 and above plan? Since $8 plan roaming data is not shared with SG.
So mean you also got "E" connection aka no data connection while in JB too?Mine is the $11.80. I would say connection is better in my case in Batam than in JB.
Sorry, I don't really observe whether "E" or not, but it wasn't like no connection at all. There are spots whereby is good and some not as good.So mean you also got "E" connection aka no data connection while in JB too?
Okay. Some spot really CMI got no internet.Sorry, I don't really observe whether "E" or not, but it wasn't like no connection at all. There are spots whereby is good and some not as good.
Its PossibleSounds like the base station in power saving mode........
