gregory_choo
Hi guys!
What is your experience for SIMBA 5G $10 plan?
I intend to use it as replacement for home internet, so might want to buy a 5G Sim Card router.
Is the speed decent?
Thank you!
Simba has a data only 5g plan , $5 only for 300gb.
No one can tell the speed if you use it in your house. So the only way is to get a Simba SIM card, put in your phone and measure speed in your home.
Sometimes its 4g is faster than 5g. But who cares, if it can give sufficient speed.
Kiwi8
Deluxe Member
Thank you!
Data only is good enough for me.
Will sign up this plan to try try.
Kiwi8
Deluxe Member
Simba is bad at my household and generally in the north area. Download I can tahan, but upload is like only 5mbps max, mostly 2mbps only. :s22:
cybertech
My Simba $10 plan the reception really getting from bad to worst. At home very often the symbol shown No Entry sign meaning sudden no signal at all and at work most of the time only 2 bars signal. Planning to port-in to M1 150GB $11.95 plan, rather pay additional $2 more for better reception. Since home broadband also with M1.
Edit: Just notice M1 mobile plans no free Caller ID, is add-on need to pay. Will skip and look for others.
kelvinti
Forget about the repeater at home.
Then, how about bad speed outside the house.
I actually cancelled the repeater installation after much thought about it.
So, Just port out. :censored: Now, happy with the super speed with another MVNO! :whistle:
Habrosus
My $10 central region full bar, 2nd slot has Malaysia Hotlink Prepaid roaming on ST, either 2 bar or 1 or nothing.
M1 works too, but I port that to Maxx to save cost.
tohchr
Port out to Singtel $15 plan lar.. Then 2nd sim use simba for travelling.. This is my current setup.
