Habrosus
- Jul 23, 2005
YouTrip conversion 3.330... OK lah, not say spending Ks...Going to drop to below 3.3.
Agreed, minute difference no diff.YouTrip conversion 3.330... OK lah, not say spending Ks...![]()
Hi is using Ichange to exchange SGD to MYR and then transfer to Touch n Go still the preferred choice ?
However I heard now there's a fee involved whereas it was free in the past.
Is there any optimal solution for now
bo pien wanHi is using Ichange to exchange SGD to MYR and then transfer to Touch n Go still the preferred choice ?
The transfer from SG Bank to MY Bank, how does the FX works?As long your Ewallet is SG issued, there will be fee involved when you topup your TnG
best solution = have a Malaysia Bank account with ATM(Debit card)
Transfer from your SG Bank to MY bank and Topup via MY bank to TnG.
Read this...The transfer from SG Bank to MY Bank, how does the FX works?
Pai sei bro mine stinkapore ac. But I use it mainly in JB. I was surprised exchange rate v gd. Also boleh land many maybank atm machine. Even gentings.![]()
Yes something like that ah. Huat ah. To me ish convenience.Okay so it is using Maybank internal FX conversion
To me, even if not high usage, also worth the trouble.I have a CIMB SG account and a CIMB MY account.
I use the CIMB SG app direct transfer to my CIMB MY account.
Rate are pretty on par with youtrip, instaram exchange rate.
But of cause, diff ppl have diff use case.
If you monthly spend about 2k RM.. than i think its worth the trouble..
If you monthy spend like 400RM.. i dunno if worth the trouble..
So depend on your needs, no correct answer, only which you suit better.
What you mean by worth the trouble?I have a CIMB SG account and a CIMB MY account.
Transfer from SG Cimb to MY Cimb and then withdraw ah?
