[Official Thread] Ringgit Exchange Rate - Part 2
potato13
Then why need to transfer to TNG? Can just use youtrip card or app directly to pay?
not all places can tap.. like if you go kopi diam, mama shop, many have QR code for you to use TnG scan but not all have the machine for you to Tap.
I think in MY is same, using CC machine for touch/paywave might carry a small fee to the merchant.
So not all will wanna add in that machine for you to tap.
the most simple way is carry Cash..
Depend on your want and needs.
vaxvms
not all can tap with cc
1 exmaple genting highland cable car buying ticket self kiosk
tab with cc n mchine ask for card pin then key in correct pin but rejected
then use tng scan chop chop go through
sallybee
Thank you ! Now I know why . Like that I think carry cash easiest. Go custom change and then bring in .
