OnePlus 13 series
anthonygreenisreal
In the same boat as u. Want to prep before tariff-driven astronomical iphone prices. Good go see android flagships being competitive. Comparing op13 v oppo x8 pro v honor magic 7 pro... So similar yet so different. Headache
OnePlus 13 is cheaper than both Oppo X8 pro and honor magic 7 pro. They are kind of one the same level. Flagship grade.
Jonesequa
Oneplus official store on Shopee during the sale period. You can try later at 8pm for the 5.5 sale on Shopee.
Pre checked out right now even with all the vouchers cheapest is $698 and its just the phone, i don't think i can even get anywhere close to the price you got, $60 off min spend 600 and the
Currently 600 flat, same price as POCO F7 Pro, which is better?
soldistance
Shoppee is roughly at $605 for 13R now. Use shopback for some Cashback. I remember it was around 590 with the Cashback. Not sure if shopback still have this though.
Prefer 1+ compare to Poco, just don't like the OS with ads.
tkte_85
Oneplus definitely, Poco's hyperOS is just not as good an Android OS that has ads inbuilt, compared to OxygenOS that's almost near stock android like Pixel phones
Chrisng_21
Hi, can i check for oneplus 13r, it doesnt come with a charger, i see that the phone support 80W fast charge, can i buy an oppo charger and support fast charge as well? If yes which charger should i buy? Thank you. I am looking for Oppo charger because i will be using this phone in Taiwan.
Veloso
If same pricing, I'm with 1+. Lol.
Can. I'm using OPPO charger, bought from CN, 100W, using on 1+ 13 & 13R, will show ultra fast charging. Never really go and time the charging speed but seem ok.
tkte_85
yes, u can also look for realme chargers too but oppo is the safest bet. Normal PD chargers seem to be able to trigger supervooc on 13R too but at a lower wattage of around 50W max i believe
s7460597
How to get 986? I get 1086 only.
First time use shopee :(
Shadowz1984
So far lowest is $976 from shopee for OnePlus 13 local phone only, any better 5.5 deals?
That's the lowest for this 5.5 deal so far. Though this isn't the lowest price of oneplus 13. Lowest if not wrong is around 950 during Mar.
tkte_85
go to shopee main page, go to 5.5 promo page and collect and save all the coupons into your account
then when checking out select the discount that best match the buying price, for 5/5 is $110 off 900 for OP13, $88 off 600 for 13R
BotakGirl
and may i know if all oneplus got this build in app like same as oppo app market app ?
dantom04
I thinking of getting it... But my hp still ok... If I get it in Nov or Dec this yr.. will the price drop much more? Have not follow the price trend of OnePlus model.. anyone got any thought on this..
