OnePlus 13 series
BotakGirl
dont have a oneplus to test
anyone can try see can access to it?
as i dont see in google play store
tkte_85
I thinking of getting it... But my hp still ok... If I get it in Nov or Dec this yr.. will the price drop much more? Have not follow the price trend of OnePlus model.. anyone got any thought on this..
by the time in nov dec, oneplus 14 would have come out in china, and the demand for 13 would have dropped alot since everyone would be waiting for 14. and you probably have to ask yourself if u wanted a last gen processor flagship at that stage, esp if the price similar to now. Do not expect price to be much lower than now also
tkte_85
its not in the playstore, its installed seperately through apk. but i just tested it and it doesnt work. Anyway why need to have this when the main point of having Oneplus global OS is that its free from all these extra stuff and being close to stock android
soldistance
Won't drop much, I was comparing between 12 and 13R at one point this year but 12 was still 900ish.
s7460597
go to shopee main page, go to 5.5 promo page and collect and save all the coupons into your account
then when checking out select the discount that best match the buying price, for 5/5 is $110 off 900 for OP13, $88 off 600 for 13R
Ordered at $976.
Thanks for your patience and help.
s7460597
The next update may have arrived. Maybe better deal to pre order with freebies and discount?
Chrisng_21
If same pricing, I'm with 1+. Lol.
Can. I'm using OPPO charger, bought from CN, 100W, using on 1+ 13 & 13R, will show ultra fast charging. Never really go and time the charging speed but seem ok.
Thank you for your reply, I see that oppo have 2 type of charger which is 100w and 80w, if I buy 80w will it support ultra fast charging? If I am looking for a fast charging power bank for OnePlus 13R. Any recommendation or how much V and A I should be looking at? Thank you.
Chrisng_21
yes, u can also look for realme chargers too but oppo is the safest bet. Normal PD chargers seem to be able to trigger supervooc on 13R too but at a lower wattage of around 50W max i believe
Thank you for your reply. For PD charger what is the V and A I should be looking at? Or I just purchase a 60W PD charger will do? Thank you.
tkte_85
for Oppo supervooc both 80w and 100w work. For PD chargers i believe 65w would work too, but note that i believe it will only charge at the said 50W when the battery has below 60%, it will use lower wattage at higher battery % left
Veloso
Yes, will support. Not sure about PBs, but I using Vention ones, should be max 22.5W only.
tkte_85
good price and the cleanest OS with a hardware silent/vibrate/ring slider, although op13 is probably gonna be the last one in its line to feature this, the next one is probably gonna be replaced by a button
Chrisng_21
Hi can i check if i am purchasing Oneplus 13R casing from taobao, what is the model in chinese that i can search for? Is there anyway to transfer all data including photo,video, chat history from Oneplus 7 pro to oneplus 13R? Thank you.
KeYoKe
一加ace5
Use the clone phone app from oneplus to transfer between op7 pro and 13r
anthonygreenisreal
The price don't seem to drop much for OnePlus.
radzkal
I know this has probably been discussed before but recommendation for screen protector? I assume the pre-applied one is not good enough..
anthonygreenisreal
I went to hp inspiration at Marina square to get the matt screen protector that they cut out using the machine. It is really good.
