OnePlus 13 series
anthonygreenisreal
By the way, does anyone know how is the curved screen of Oneplus 12 compared to Oneplus 13? I didn't have a chance to see a Oneplus 12 before.
The curved screen of OP12 is quite curved, like those Chinese curved screen phones you can still see at Challenger.
Shadowz1984
The curve screen for OP13 is still okie. Much better than the 12. If you wanna know how curved is the OP13, can check out the Oppo Find X8 Pro display set.
I have Oneplus 13. Bought for my wife. So just want to know how curve is Oneplus 12 screen compared to 13
radzkal
I find the original OnePlus 13 sandstone case really good. Feels good in the hand and the magsafe is really strong. It is also quite sleek and keeps the phone no bulk.
Bad thing is the case maybe not as protective against drop since it's quite thin and it does lodged Abit off the case when I dropped it.
do u remove the plastic sheet from the case when u wirelessly charge? i tried wireless charging using a normal qi wireless charger and phone heat up so much
MangoCAT
Too bad no local 13T. SFF phone factor But i asked one of the shopee seller they say support banking and singpass app for CN sets but is their words.
