RyanJ
- Jun 18, 2015
Not every new yearly release is gonna be groundbreaking or better than the previous gen.
Just like Xperia
so did u buy the x200u?If 200u is so good, I wonder what else to improve for x300 series
I read that there is a proposal to reduce the thickness of the cam module by have more reflective surfaces.
Hopefully that will not worsen image quality, or add in more image post processing.
so did u buy?Shoppe sale now 1270 can get 512 gig version!!
Ya. Now I'm just waiting for a ultra foldable phone with PC desktop mode lol.Just like Xperia
Did notso did u buy the x200u?
Starhub, theres HD , not sure if thats what you're looking for.Anyone here using china variant x200p or x200u can verify got volte ?
Does it show volte on your x200 series ?
hmm not really..
only 5G Starhub HD
Bcos Ived used OnePlus phones b4 without volte I can't use googles maps/internet while make phone calls...
X200 series can ?
Bingo driver problem...Simplest solution is the moment u make a normal phone call , does the 4g/5g icon change to h+ or 3g ? If yes means it doesn't support voltehmm good question ... will have to try it out later...
usually, unless its a driver type situation ...
immediately i can think of a workaround
--> maps , use it, and use whatsapp voice call. [ data mah ]
--> use waze or others, then normal call.
Apart from my wife ? lolBingo driver problem...Simplest solution is the moment u make a normal phone call , does the 4g/5g icon change to h+ or 3g ? If yes means it doesn't support volte
Do appreciate your time and effort to try out for meApart from my wife ? lol
i rarely have normal voice calls,
will test it later for you when im heading out to the gym,
eh.. the rest of the siao eh also no drive like me meh .... all x200u diam diam >,>
I think status bar showing HD is also known as VOLTE, some telco do market VOLTE as HD voice.
do correct me if I'm wrong.
Thanks so much for the verification bro...yours is cn set right not the global or malaysia set?@Blueberrytea
Just tested
With driving navigation on even though I'm just taking the bus
Called my mum using normal dialler copy number , paste on dialer , call
Swipe and between apps no drop apart from poor sound which I guess it's my airpods pro issue or the Bluetooth
It does show 4g+ at times but mini map navigation whilst on call works
China from wimall ShopeeThanks so much for the verification bro...yours is cn set right not the global or malaysia set?
