Vivo X200 Series
Chevalier
Thought I was the only one with dual link not present
Thanks for the response
As for 6hz
what router or access point ?
Although slightly off topic here and should be in bandwidth thread
I would guess your channel isn't suitable
E.g when my AP set to 100 channel or 108
My wife's old oppo cannot get to 5ghz
Changing to 64 dfs channel resolved it
So play around your channel settings
6ghz is even more picky as it overlaps the restricted dfs channels
will check it out, I use Ubiquiti at home.
Chevalier
If 2.4ghz and 5gh are doable, then from there initiate the channel changes...
i keep 2.4 soley for IoT only on a separate network
my main network is 5ghz and6ghz only. 16PM has no issues connecting to 6E and speedtests reach 1.5gbps.
the x200U peaked at 800mbps? wifi settings show its only connected to 5ghz.
menace66
I finally received my red 1TB Ultra after re-ordering from a different seller after the 1st seller on Shopee cancelled my order.
Had some issues with Gmail, whatsapp notifications but fixed it by setting auto-start, associated startup and background power consumption.
Now I am left with my work profile push notifications. I cannot set the same settings as the personal apps above. Anyone managed to find a workaround? Not a deal breaker though and might be a good thing I am not always stuck on work. lol. Let me know if anyone has a solution. Thank you. :)
BradenHeat
check for firmware vivo,
6ghz should have options to allow it to connect, as it means its a channel selection issue. since it can see but not join.....
as for the rest will trial and error liao
then got buffet for us ?
lol
which shopee seller ?
push work, need to install mdm separate profile de..then from there tweak the settings...ive no issues with microsoft work profile.
Chevalier
microsoft suite for work?
Chevalier
lol
yep, i updated to the latest firmware, factory reset and setup as new.
PS : you and your buffet ah....
PPS: i followed the instruction to scan the QR on my iphone, it brings me to a link on the appstore but says i can't access it due to region
BradenHeat
so no luck on the wifi ? try someone's else or post it on the bandwidth and networking there...
ubiuity folks still active.
as for the QR code, as ive mentioned prior, i gave up and just use whatsapp 2nd link suat. Which is better since there is icloud backup from there....and if worst come worst, can always leave my iphone at home and whatsapp will still work.
buffet is a edmw tradition HOKAYS.. :o:grin::crazy:=:p:s42::s42::s34:
eddy0505
Pros and cons of the 3 Ultras in photography. Unable to embed, click to watch it on youtube can liao.
eddy0505
I think most china rom/brand phones dont have wifi 6g, my max speed with my china wifi 6 router can achieve 1.4Gbps connecting to 5ghz network.
BradenHeat
odd... my u7pro , i can connect as wifi 7 at home....
6Ghz also can... unless i mistook it.. but 1.2gbps easily
eddy0505
Wifi 7 you can only achieve max speed /triband if your phone supports 2.4/5/6ghz if not mistaken. Iphone has 6g so I believe its max speed definitely exceeds vivo x200 ultra. Your wifi 7 speed for ultra probably only utilized 2.4 and 5ghz.
eddy0505
Lol still better than what sony is putting out.... it was bad with 'em xperia folks :s22: :spin:
I thought oppo would excel in potraits but seems like its scenario based also. Vivo overall can take any kinds of shots, certain situations need tweak a bit (hopefully can be resolved in OTA updates).
RyanJ
Next Bilibili :
建议收藏】哪款手机更Ultra?2025年旗舰超大杯手机横评 ]​
当vivo x200 Ultra拥有了变形宽银幕镜头,你打开了电影世界​
Something slighly off topic :
【4K转】Xperia 1 VII日本实测|Sony Xperia Intelligence登场!手机拍照还是最自然最好看|粤语 中字​
that auto framing is indeed one of the better ones
If vivo could copy that , 1/2 of the software, it will be at the very top of video recording on mobile
Cannot seem to open the links on chrome mobile.
Firefox needs me to install apk.
Wats the Sony autoframing about ? It tracks the subject?
BradenHeat
lol if they had retain 1-inch + 35mm confirm god-like for 3 years.
rest can be done via software, and i believe its easily copied from sony
lol you change to desktop version can view liao
autoframing, uses the wide angle 14mm as a [ area map ] , whilst theres another use for the larger 23 mm ? to track .
basically sony gods of the yester years still in use.
the way they implemented the tracking, the interface, i really hope vivo can pick up a thing or two...
menace66
lol
Thank you. Got from George tech. I managed to get Teams to push notifications out by app info --> all permissions --> auto-start but outlook still does not push the notifications out with the same settings.
Looked everywhere under settings but Under work profile, I can only access the notification settings unlike the personal apps where I can access background management. Any other ideas I can try? Thank u.
BradenHeat
Means your company IT buay zai, not using MDM to push profiles to segregate the work profile for you.
if you dont need Intunes or Airwatch, means your company isnt setup for such clear cut . Then just your person outlook and sign in bah
BradenHeat
Interesting thing ive just discovered : those 200mp shots cannot be uploaded to google photos or drive...
says too large
