Hi, need some advice.
I am currently on a 1gbps plan, upgrading to a 10gbps plan.
PC has always been running wired direct to router. However, the existing hardware is not sufficient to support anything beyond 1gbps hence i am looking for solutions.
Initial thought was to run a 10gbps PCIE card, but my graphics card might be blocking the PCIE slot. Anyone has recommendations on the slimmest 10gbps PCIE card? I have at most 6mm-7mm from my graphics card to the middle of the PCIE slot further down.
An alternative would be to use a USB based ethernet dongle, but there doesn't seem to be a 10gbps one that could work with USB 3.1 (Type A/C).
Just for info, i am using a Gigabyte Aorus B450 Pro Wifi MOBO.
https://www.gigabyte.com/Motherboard/B450-AORUS-PRO-WIFI-rev-1x
