Why so hot la!!!
Dopod007
What's gonna happen to us? Now already feel like open space sauna
Free sauna everyday in Sinkapore when you step out of the house 😆
When temp reached 45C, it is not safe under the sun, can die of heat stroke. Mankind probably needs to invent a spacesuit with temp control just to venture outdoor...
hachi
The atmospheric carbon dioxide (CO2) concentration at present day is approximately 425.82 parts per million (ppm), as of May 21, 2025. This is significantly higher than pre-industrial levels of around 280 ppm. The global average CO2 concentration in 2023 was 419.3 ppm.
Mankind needs to lower greenhouse gas CO2 ppm to prevent the earth from getting hotter year by year. Need to depend more on green renewable energy rather than fossil fuels
AI and DC are not helping....
Dopod007
Advice from AI on 45C temp.
Going outdoors in 45°C (113°F) heat can be very risky, especially for prolonged periods. Here's what you need to consider:
Risks:
Heat exhaustion or heatstroke can happen quickly at that temperature.
Dehydration occurs faster due to extreme heat and sweating.
Sunburn and skin damage are likely without protection.
People with certain health conditions (like kidney or heart issues) are more vulnerable.
If You Must Go Out:
Go out only if absolutely necessary.
Limit time in direct sun; seek shade frequently.
Wear loose, light-colored clothing and a wide-brimmed hat.
Apply sunscreen (SPF 30 or higher).
Drink water regularly, even if not thirsty.
Avoid strenuous activity.
Monitor for symptoms like dizziness, nausea, rapid heartbeat, or confusion — signs of heat-related illness.
Safer Alternative:
If possible, stay indoors or wait until early morning or after sunset, when temperatures are lower.
helloicanseeu
spacesuit oredi invented ...
its just like condoms, sometimes its just not practical to use them every time a need arises.
Dopod007
Keep clearing forest, still expect everyone to keep Aircon at 25C.
Overpopulation already!
With 10M population in Sinkapore, it will be hotter than now. More AC needs to be on, more hot air coming out. So not wise to further increase population!
coolmyth
These two nights the weather really jin steam.
Hiding inside air-con room. Can't imagine life without air-con, like during moi si ginna days. o_O
