Oppo Find N5
GeSteSoh
Noticed that the Camera keeps losing it settings
For eg.
1. Geo tagging keeps turning on by itself
2. Already set double tap power button to launch camera, suddenly this setting disabled by itself
Anyone else noticed this?
Noticed that the recent update has removed the feature: double tap power button to launch the camera?
stupidog
I forgotten how and where to deactivate this feature
I wanna view the contents but it was hidden
Anyone knows ?
Success
There are hybrid sim slots that hold both NanoSim and MicroSD cards. I understand that not everyone knows about it.
silverstone
yeah, i think sony xperia phone has this features, and probably xiaomi redmi note 14
but i think only can 1 sim and 1 microSD active at a time, cannot 2 sims and 1 microSD...
twosix
Not recommended to use microsd card in newer phones, cos these cards are just too slow for the phone. And may cause issues when using the phone.
4D.TOTO&BS
Software update
CPH2671_15.0.1.831 (EX01) | 445.70 MB
Communication & interconnection
Adds remote control support for Windows PC. You can now control your PC and access PC files remotely with your mobile device.
Improves the cellular network algorithm for smoother network connections.
Apps
Adds the Drag & drop feature that allows you to use the gesture to perform actions on images and text in third-party apps. You can change the settings for this feature in "Settings - Accessibility & convenience - Drag & drop".
You can now use fuzzy search with space in Settings.
You can now search for app names in Settings to quickly view app details or manage the app.
Optimizes the search result display order in Settings.
Multimedia
Adds the Speaker cleaner feature which can clean speakers and ensure optimal speaker performance. You can change the settings for this feature in "Phone Manager - Tools - More - Accessibility & convenience -Speaker cleaner".
System
Improves the floating bar responsiveness of floating windows.
Improves the animation when exiting the Quick Settings and Notification drawer for better responsiveness and smoother transitions.
You can now seamlessly open an app from quick functions when the screen is locked.
When notifications are stacked, the latest notification will now display a summary showing the number of undisplayed notifications and their sources.
Improves the keyboard layout for more convenient operations and more appealing visuals.
Integrates the June 2025 Android security patch to enhance system security.
To view more or join a discussion, visit https://community.oppo.com
