I usually board at kovan.. last time still can take backward to Punggol then come back with a seat.. nowadays with a new Punggol Coast might be too long to do that.Do you find some line got a problem?
eg NEL, it’s already fully packed at Sengkang… and the subsequent stations passengers are unable to board…
means those at the middle of the lines towards the city or interchange will not be able to board the train because it’s full.
Earlier trains hv to start early too.Won't it catch up with the earlier train also? In the end delay for everybody
Got chance for what?My solution is vote for change... maybe nxt GE got chance... now just diam diam follow 65%
The peak dont starts at 4 - 5 + am , i.e 1st train.This got nothing to do with adding carriage front and back.. but it doesn't really solve the issue during peak hour.. maybe help a little by prolonging the peak hour duration to reduce the impact of crowd...
Think they say before they need time to maintain the train when station is closed.. so if start earlier mean not enough time for maintenance..
Two out, one inNet zero immigration. One out, one in.
You say won't affect then won't affect ah.. how u know how long they need to do maintenance?? Probably maintenance until 5+am..The peak dont starts at 4 - 5 + am , i.e 1st train.
So wont affect their maintence.
Only affect the peak hrs.
If the train is full.. likely will.. now anywhere in the train just need to take 5-6 steps to reach any exits.. but if you are at the end of the additional carriage.. that's probably 30-40 steps already.. if it's full the people cannot move until the one in front start moving after the train has stopped etc some of the people have alighted to make empty space for people to move..Earlier trains hv to start early too.
Dont think will catch up.
Maybe 30 sec waiting time?
Just 2 cabins, how long will be the delay , 2 mins?
Or allocate a small single section at cabin 2 w door that only allows for exit from cabin 1, not allow to stand there?
Now also hv ppl at the door, temp exit to let ppl out n enter again.
I mean peak hrs is Not at 4-5+am i.e 1st trainYou say won't affect then won't affect ah.. how u know how long they need to do maintenance?? Probably maintenance until 5+am..
You mean starting the first train earlier at 4-5am right?? That's the time they are doing the maintenance right?? What does it got to do with peak hour. If you start the train where previously they are doing maintenance then it obviously will affect it..I mean peak hrs is Not at 4-5+am i.e 1st train, so wont affect the maintenance.
No, I mean peak hrs is not at 1st train.You mean starting the first train earlier at 4-5am right?? That's the time they are doing the maintenance right?? What does it got to do with peak hour. If you start the train where previously they are doing maintenance then it obviously will affect it..
I mean if they are that stupid then deserve to sit in train as it loops in perpetuity till they become... dust and bonesThen how the people going to alight?? Take longer each train and each station for both ends.. there is only 1 door to serve two carriages..
Actually our 750V systems already dictates that trains can't be faster than 2.5 mins interval. It's a physics limitation. 1500V ones such as the one in NEL in theory may achieve 2 mins intervals...Maybe 30 sec waiting time?
