Aftershock shortchanged me?
justln
I was researching on prebuilt PCs and ultimately decided on Mansa, they deliver all the boxes of PSU/GPU/Motherboard with your PC.
Bought Super Flower PSU 1000 even tho it's overkill.
PSU really no joke, a good one should last until you change PC, not pop pop randomly.
Spectre007
har? chiu bought a full pc system and didnt even bother to open to check the components insai? you ok bo?
rEe_TaN
better re check yr specs again.
gamersgate is not deepcool, and it is known to be chui, subsidary or not. its like u go buy a volvo, but came a geely. better recheck yr specs build, i doubt they will do this. its almost borderline fraud
Read HWZ Forum Rules!
I have played with corsair, seasonic and thermaltake, none actually failed me for like 5yrs + .. this is the first time i had a psu last less than 3mths..
Solidus_GZ
TS did you get any aftershock when your psu kaput?
I brought 1 cpu then upgrade 3070 n psu later, for some reason when ever I plug in the cpu the breaker trip. Both old and new psu the same I wonder izzit my breaker problem or psu
rEe_TaN
I only used the cpuid, gpuz and memtest to make sure specs are accurate and stable..
But yeah...i forgot to check the brands/model etc..
hahaedmw
sorry i made typo. i mean gamemax psu. im nt sure about gamersgate psu. care to share a pic? cause its quite disturbing . .
jiagong
after what happened you still dare to buy PSU from them? best to just do your own research, decide on a PSU and buy it from sim lim
86technie
So i bought a full pc system from aftershock since on feb and last night psu kabut with 2 loud pop sound.
And today after talking to the CS through via WhatsApp. I decided to replace another brand of PSU from them.. But im curious why the current brand deepcool is so bad so i decide to peek on it.
Turns out the PSU is not deepcool but rather it is gamerstorm, a subsidiary from deepcool brand and somehow i feel short change.
The invoice stated it is Deepcool 850w ATX 3.0 cyber platinum but it turns out to be gamersgate..
Should i ask them for clarification??
Which is why if anyone ask me can I recommend Aftershock is no.
You be shock they use a lot of cheap parts, motherboard, case, SSD, PSU, fan etc.
Depending on which GPU you are using.
If it uses this 12vhpwr confirm the PSU cannot take it.
I did saw one of AS rig it came with RTX 4070 but uses a Deepcool non-modular PSU
with no 12vhpwr.
Wattage is 850 watt which is by right enough but like what TS encounter the quality is....
You can ask AS what they can offer you, proably they will offer you the next worse option. :s13:
hardindex
Should have diy from sim lim. Pretty sure those regular shops will not do such things.
simlim one is pick the parts they build, think they charge the labour cost. Labour cost absorbed if you brought all from same shop. They always have prebuild one for customer to choose
Saw china one sibei fierce anyhow chop carrot
6.92 gOk:/ K@J.VY 09/11 假装成不懂电脑的小白,预算5000勇闯线下电脑城装机, 会被坑的多惨?不仅遇到了8年前的古董显卡,还被四五个壮汉直接拖进店里......# 实拍暗访 # 电脑城 # 电脑整机 # 装机 # 科技数码 https://v.douyin.com/veiIzLyizkU/ 复制此链接,打开Dou音搜索,直接观看视频!
coyote
Just stick to the usual shops like fuwell, pcthemes, laser and it should be fine... If one knows nut about computers, then too bad. I hope those shops are still around, didn't go there for ages...
Darkshadows
Take it as a lesson learned and never look back again. I've already moved on as I have my fair share of experience.
rEe_TaN
with no 12vhpwr.
Im asking them to change to another good brand .. they claimed the model i had is oem manufactured by gamerstorm and it is make by deepcool ..
