Aftershock shortchanged me?
white_prince
So i bought a full pc system from aftershock since on feb and last night psu kabut with 2 loud pop sound.
And today after talking to the CS through via WhatsApp. I decided to replace another brand of PSU from them.. But im curious why the current brand deepcool is so bad so i decide to peek on it.
Turns out the PSU is not deepcool but rather it is gamerstorm, a subsidiary from deepcool brand and somehow i feel short changed.
The invoice stated it is Deepcool 850w ATX 3.0 cyber platinum but it turns out to be gamerstorm..
Should i ask them for clarification??
They will say u change it yourself
kimsix
Its 3am .. 2 loud pop sound and i was stunned.. only came back to sense when i smelled burning smell and i shut down the pc..
I thought it was a ghost residing in the pc .. kinda scary you know..
i always see my fren 3am still online
are you surfing jap documentary like him? pop means ruined liao... :o
is this yours? looks decent, gamerstorm i think just a brand name but still under deepcool
https://hwbusters.com/psus/deepcool-pq850g-atx-v3-1-psu-review/
rEe_TaN
Unfortunately the model is gamerstorm ZC850D which isn't appear in any where..
Even the SPL list for all models, the ZC850D is not inside as well..
Now out of curiosity.. this zc850d is seems to be very rare... i cant even google-fu this model
ballistixxx
So after you buy from AfterShock, u really AFTER that SHOCKed hahahahahahahahaha
XCalintz
But im happy with their services. They actually took the time to call me after i WA them on then findings i discovered.
Have you thought that if they dont shortchange the psu with OEM model without ur knowledge, you wont even have this problem/downtime & the shock of hearing 2 pop sound from ur PC?
selemuse
"The invoice stated it is Deepcool 850w ATX 3.0 cyber platinum but it turns out to be gamerstorm.."
Isn't it normal practice for the vendor to do this without informing the buyer? If so, no surprise it is called AfterShock :D . Joke aside, I once think of getting their gaming pc as it has very favourable price but I don't think I want to risk receiving shock after discover similar brutal truth. It is not cool, and cause storm between buyer and the vendor should this occurs.
robie_aibo
Just stick to the usual shops like fuwell, pcthemes, laser and it should be fine... If one knows nut about computers, then too bad. I hope those shops are still around, didn't go there for ages...
Fuwell still around. Bought my rigs from them this March. Labour cost absorbed and collected within 2 hours for both rigs.
tidiii
maybe they gave wrong?
my pc also the cpu cooler was stealth but they gave some generic fan
they sent a guy down to replace it when i email them
honestly its' quite difficult to know what parts u get
dontwastetime
I was researching on prebuilt PCs and ultimately decided on Mansa, they deliver all the boxes of PSU/GPU/Motherboard with your PC.
Bought Super Flower PSU 1000 even tho it's overkill.
PSU really no joke, a good one should last until you change PC, not pop pop randomly.
But their prices like super expensive for same specs , so sad
dontwastetime
I never buy a AS before but given the number of their PC in my workshop.
To my knowledge what part they use in their build are not really known to users.
Unless you customize the individual part but than they can last minute swap/change
which I also heard before.
Like most here mentioned if want quality build go Sim Lim, Aftershock is like that.
Source cheap than sell high but than how many times you have to repair is another question.
Some user like you is PSU blow, while some are faulty/brick motherboard as they use
their own custom BIOS.
If you start the PC and see a Aftershock logo the motherboard is using their BIOS.
The mobo BIOS tend to have issues down the road thus I do have cases of
their mobo bricking and no way to save it except RMA.
If you wonder what is mobo bricking, it is a issue when you start the PC.
No display even though the PC is running, you swap RAM, GPU but
it refuse to start.
I think I did post a thread about Aftershock rubbish quality in HWC. :s13:
https://forums.hardwarezone.com.sg/...ou-should-take-note-when-you-buy-one.7127128/
justln
Ok la, not super more expensive vs other brands.
Contacted so many prebuild sellers, they are the only one I'm impressed with the service.
Godeau
anyone remember last time sls got this nice uncle at level4/5. He a bit chubby chubby kind and look like malay but can speak chinese huan. wear specs. last time i always find him to help me build custom pc because he very friendly and won't tok carrot.
now should be at least in his late 40s/ early 50s liao
Bell systems? Dave ah?
Godeau
for me PSU is number 1 important part you need to choose, I prefer Seasonic, and they dun have that.
Had a Seasonic explode on me(>5years) with flame recently, luckily it never took out other components inside the case.
Quite an expensive psu too, $300++ 80plus titanium model, has a long warranty so rma-ed.
junjie433
Anyone got a wrong part which is more expensive than what is stated in the spec?
