Xiaomi 15 Series
dreamcast18
U eat one less Michelin stared restaurant can liao.
but but but i usually get the $5 bowl from Hill Street Tai Hwa Pork Noodle.... okok i switch to indomee from valuestore from tomorrow! after 1 yr....should have enough to pay for next Ultra!
The "frustrating" thing is the casing specifications may change as the models change.
The buying never ends....
Planned obsolescence !
dreamcast18
May Sec update arrived
Raven.SG
Anyone have any idea if they will restock the Photography Kit for the 15 Ultra? Not sure if I should just buy it now or wait for its restock. I was planning to use this phone for my upcoming holiday, late-June.
I emailed and called them, and they just said they have no update on when it will restock. If anyone has any experience with the Xiaomi 14's Photography Kit, do share if it was restocked and if you know how long, thanks!
siatc
buy from carousell
speedknight
Moderator
Moderator
Mine is local set. But just try agian within this few days. Sometime it's staggered
jeff79
Is your set bought from local seller? I'm not getting any updates since March update.
Mine is 2.0.109.0.VOCMIXM
Hmm weird that I've only 1 update so far. Mine is also local set. Region is Singapore 🤔
vocmixm is xiaomi 15 global version. There is a newer firnware dated 28-apr 2.0.112. Have you manually check for update in settings my device click on the hyperos logo?
Can use https://miuiver.com/ to check for new update and the changlog.
ZaxGax
Yes thank you! I managed to get this update after switching to UK region. But is still weird that I've only received this update outside of sg region 😢
hipaws
Hi, any idea if SG is gonna release XM 15 pro/ 15s pro ? I saw it over at CN xiaomi website for order.
