Milo-Dino
- May 15, 2009
Thanks.You can only utilitize the 5Gbps bandwidth with wired devices basically if you get the SingTel 5Gbps plan with the lousy SingTel WiFi 6 device.
If you are only using wireless, then the lousy SingTel WiFi 6 device (with 1Gbps WAN port) will limit your 5Gbps Internet to 1Gbps, not 2.5Gbps. Even if you upgrade to HB611-SGST (with 2.5Gbps WAN), you will be limited to 2.5Gbps.
On the other hand, you can get HB710 (with 10Gbps WAN port) from outside (S$192 from Starhub, similar price from Carousell) to have the ability to fully utilize the 5Gbps bandwidth.
If you have a choice, look at other ISPs which offer better value 3Gbps or 5Gbps plan.
I'll prefer to stick with singtel since they can probably troubleshoot if anything happens (don't need me to head down to parent's place)
Maybe can even consider the 10gbps entertainment bundle with singtel tv sports group as well as the TPlink HB810 router provided for S$66.44. If not maybe just sign the 3gbps with HB611 and get limited at 2.5gbps
