Starhub Giga
highsulphur
Does anyone know how to activate ROTW data roaming for APAC countries? Or die die must use APAC data roaming pack?
a4973
Here u go.
Hi hi!
Here’s a special surprise from me to you: use promo code <gigaX3uF> to enjoy $10 plan FREE for 4 months
• 10GB/mth with free Rollover Data
• 300 mins, 300 SMS
Plan reverts to usual price of $10.10 after 4 months.
How to use gift code:
1. Download the giga app, select $10 plan
2. Enter gift code and check out at $0
3. Receive giga SIM card and activate
Download the giga app to sign up with Gift Code <gigaX3uF>, valid till 31 Aug 2023. https://tinyurl.com/gigafeelsgood
Hi all, remember this promo? I just realized that I have a gifted number and its sim card with me still unactivated. I can see it in my giga account. Any idea if I activated it now is the free 4 months subscription still applicable? Thank you. I've reread the promo TnC don't see any that says line must be activated by xx date.
froztheart
Like that only by trying that you will find out. :s13:
Notbbfa
Anyone unable to make outgoing calls with Giga? How to fix? Their customer service doesn’t reply at all.
Volte is automatically enabled on all (latest) iphone models, right?
Searched high and low for the VoLTE option in settings and can’t find.
those on iPhone what’s your mobile data network details keyed? Just “Giga” for APN field and other fields left EMPTY, like what they mentioned on their YouTube guide?
sibeiTrolled
Not IOS user here
Have you looked under Settings -> Mobile Data -> Mobile Data Options -> Voice and Data?
I was unable to make outgoing calls with my android phone voWIFI, could be a similar case to yours.
Have you tried just making outgoing calls without any wifi connected?
Are you to able recieve any incoming calls?
They also have a written guide
https://www.giga.com.sg/FAQs_Details.aspx?QuestionId=4782
  • Name: giga
  • APN: giga
  • Everything else is left blank
Yes, all should be blank
davi502
What is the $20 Sign-Up Offer about?
It’s our way of saying “welcome!” 🎉 From 04 Apr to 30 Apr 2025, all new and existing subscribers who activate a new line on eligible plans will receive a $20 credit (gigaBucks) in their gigaWallet! The credit will be reflected in your gigaWallet within 10 business days after successful activation of your new plan. The eligible plans are:
  • 100GB $10.19 4G plan
  • 300GB $15.28 4G plan
  • 300GB $18.33 5G plan
  • 400GB $20.37 5G plan
  • 1TB $28.00 5G plan
More details here
Crimsom
Received email from giga on enhanced network.
Realized that Giga 5g now supports NSA network.
gaoqikai
Shared the email here to see?
I think they mean this email:
Hi hi,
We've enhanced the giga App and network for better performance. To enjoy the best experience, simply restart your mobile device by powering it OFF and ON.
Thank you for supporting giga! Have a good week ahead.
From,
the giga team
Not sure about whether giga uses NSA, before this email. Previously on MR 5G, both SA and NSA are available.
iPhone users can go into field test mode to check
marcoyeo
Not sure anyone encounter dropped 4G network signal past few months... it is like every hour signal drops. Anyway I going switch to another MVNO
sadboy
Could you please double-check that your APN (Access Point Name) is set to 'GIGA' and not 'SHWAP'?
Although 'SHWAP' is known to work with GIGA SIM cards, I've noticed that it can occasionally cause data issues if configured to 'SHWAP' instead of 'GIGA'.
By the way, there's also an issue I've encountered before while using GIGA.
I twice lose network connection and data in specific areas. The data issue typically resolves itself once I travel to another MRT station or location. This has also happened to other friends.
marcoyeo
Double-check my APN is set as "giga".
nomoreliaola
just got my honor 200 smart 5g hp , spent the past 30 mins registering to giga 4g . no matter automatic or manually registering also cannot do so. anyone experienced this before? it can detect the giga apn but it's showing no network
sibeiTrolled
So it is no network or you have 4G only?
Did your previous phone work the the SIM card? Got try putting it back?
EDIT - GG, my reading fail. Edited post to better reflect comprenshion of post.
if use back old phone or other spare phone but still no network, just drop a message to GIGA either through the app or Facebook.
nomoreliaola
my giga plan is 4g nia. the hp fail to register to my 4g network, regardless automatic or i manually choose giga 4g.
