Egate bangkok
froztheart
u will be in BKK on 5 july? :oops:
i read there are facial biometric ID auto gate since Dec 2024 though didn't see one since used egate for my last trip (before may 2025)
Register semo facial, why need register. nani 🤯
If you referring to eGate like SG's, it's been there since last year leh, have utilised it every time I was there since 2024 IIRC.
Now only need to try eGate again after this new TDAC implementation.
popdod
hopefully someone can finally confirm egate usability for SG as i wanted to register for facial ID for next trip
before that. last year I’m able to use eGate without any obstacles.
so dont know they flip their policies :s13:
recently Thailand is clamping down suspicious tourists. too many foreign crooks disrupting their peace. :s13:
rrr2015
even if they flip, at least make an official announcement mah
rrr2015
This one is when departing from Thailand, which enables one to utilise the self check-in kiosk?
Read liao don't get it. :s13:
thai certainly have queer way to do things. it says they only retain data for 24h, so i don't know what purpose does it serve :ROFLMAO:
anyway with egate i can already depart using egate as well.
froztheart
thai certainly have queer way to do things. it said they only retain data for 24h, so i don't know what purpose does it serve :ROFLMAO:
Yeah, so don't get what's this facial registration is for.
Already able to utilise eGates on Arrival and Departure. :s13:
rrr2015
i thought they implement like taiwan, just need to register once. so at least i got two options to enter the kingdom
froztheart
Nah, without it already able to utilise the eGates.
Just that now with the new TDAC, need to verify whether the eGates on Arrival still usable for Singaporeans.
~sabaisabai~
Just came back from bkk, no issue with egate departure
Btw, was given 60 days stay when arrived last month in May. As shared, i used egate for the arrival, no issue too
~sabaisabai~
I did register TDAC, but they did not check. Not sure if is recorded in the system.:p
~sabaisabai~
when was the time you cannot use?
I was in bkk in May and just returned to sg, able to use, both arrival and departure, no issue at all :p
