Redmi Pad 2
Dorkable
Apparently, the Redmi Pad 2 Cover is inside the box with the tablet.
I bought Mint Green, but no matter how I look at it, it is light metallic blue 😆 Do you guys see green or blue?
sibeiTrolled
Your last picture looks more metallic, but the 2nd pic has a hint of green and blue.
Totally different from the website sia!
networked
same color as mine. yes, it looks like metalic blue. mine is 4g version. darn there is no pen included.
where did you ordered yours? mine from xiaomi website and there is no EIN sticker.
Dorkable
I got mine from Xiaomi Authorised Store on Shopee.
Dorkable
By the way, just wanna share the following:
1) The Pad 2 charger is a cheapo non-QC type. I had to use my own 18w QC charger.
At the same time, I tried Power Delivery with type C2C cable and it does fast charge the Pad 2. This is a bonus as Pad 1 didn't support PD if I recall correctly 😗
2) The auto brightness is kinda sucky on Pad 2. I decided to have mine disabled and go manual control instead.
3) I am using 闪魔 aka Smart Devil's matte tempered glass screen protector on my Pad 2, looks and feels tons better now 😀
Xie_Minghao
Should get redmi pad 2 or the redmi pad pro? Difference is the wifi 5 vs wifi 6 and dolby vision? Is the dolby vision make the screen more vibrant?
Dorkable
It really depends on your priorities. On paper, Redmi Pad Pro or Poco Pad outweighs the Pad 2 in terms of positive traits. The only better factors Pad 2 has are:
1. Better battery life.
2. Slightly cheaper price, especially if you buy the 4G version.
3. Android upgrade up to 17 as opposed to Pad Pro's 16 (based on Xiaomi's past trend for their non-flapship devices).
4. More compact size.
Everything else, Pad Pro wins by a long mile. Even if you put Dolby Vision aside, the fact that Pad 2 has a non-laminated IPS screen is sucky already. But if you don't mind that, then ignore what I just mentioned 🙂
Xie_Minghao
So redmi pad 2 is non laminated screen and redmi pad pro is laminated?
Parka
Redmi Pad 2 has a laminated display.
Android tablets with non-laminated displays are incredibly difficult to find nowadays.
The base model iPad is probably the only tablet with non-laminated display nowadays.
