- Mar 22, 2011
ohh. but like that what is your pace usually if you maintain 140 to 150.Usually I run within 140bpm. I will stop running when I see 150 bpm, then just walk until it drops within 120bpm.
according to garmin, 151-162 is the bottom 5-29 percentile. but it depends on your built also, taller ppl might tend to have lower cadence.Ohh. If my cadence averages at 154. How is it?
Everyone pace is different for the same HR. Depends on age and fitness level.ohh. but like that what is your pace usually if you maintain 140 to 150.
No point tracking for now. I'm still finding what's suitable for me. I wasn't a very slow runner to begin with.ohh. but like that what is your pace usually if you maintain 140 to 150.
Exactly, but even then his avg. HR is still quite high, probably because he is just starting out.HR is just one of the indicator of your effort during that run and got to remember everyone zones HR are different. I got a relatively low max HR so my zone 2 HR is like 120+ to low 130.
I am around there, low 170s in long runs and high 170s for 2.4km.according to garmin, 151-162 is the bottom 5-29 percentile. but it depends on your built also, taller ppl might tend to have lower cadence.
i started with 140+ 2 months ago, now i jog while listening to metronome on youtube. i use 170 for longer dist jog, and 175 for 2.4km
Running is very popular in SG nowadays
Who got join run club?
Anyone using Apple Watch and find the distance reported to fluctuate around 5 percent , using the same route ?
Normally my 5k route is the same 400m . Wondering if “to and fro” cause the fluctuation
Why walking cannot single row and keep left? Need bann walking of side by side in pcn and pavement...
Series 9.Which apple watch?
I have a cheap Huawei GT Runner, only $130 that time on offer in Shopee. Bro Ender shared info in which youtubers did somewhat scientific tests and found it to be nearly at the top (take that info with a small grain of salt, i just take it as it is as i am not ngeow).
I do TTs along same routes and the variation literally is just 20-40m or so for 5k so 40m is pretty acceptable for the top end. At my rooftop which i run quite a fair bit (zero blockage from satellites), per 800m per standard round, variation ranges from none to 10m at most which is within margin error coz it involves six 90 deg corners per round so depending on how you cut them there should be differences.
If the same 400m you are talking about is a stadium;s running track, then the variation might be wierd, though i guess some watches is like that.
The weather these few days scorching hot. Even when I run in the evening,also perspire like mad.Top to bottom all drenched
Series 9.
I think I got the answer .
“GPS only records every few seconds. This results in it missing some of the distance you run in corners since the watch draws a straight line between points.”
when I look at my data , is really the case especially on curves where it cuts in deeply .
this will under report the distance and cause the reported pace to slow .
