kkkkdllmkkkk
- Oct 29, 2021
luckily i run around 11pm... not so hot
last time when i use to work in CBD, I salute those than runs at 12pm when it's scorching hot.luckily i run around 11pm... not so hot
Other cooler climate countries, it's pretty normal to see people run at 12pm
I got a question, are you able to sleep well after the run at 11pm?luckily i run around 11pm... not so hot
20250614 26degC (feels like 31degC) humidity 90% NB Rebel v4
6.13km @ 8:00min/km av
avHR@139(max150)
this run is one of the worst i had, had a tough time controlling my HR below 135. Had to walk twice to keep it down. Felt worse and more strenuous than my HM! Whole body drenched.
return run
5.07km @ 8:05min/km av
avHR@145(max 166)
body has yet to acclimatize from winter to summerHeat index temp 31 deg but at 90% RH starting to get uncomfy liao.
Still better than here in SG tho..... SG here 36 deg C Heat index just now morning 8.30am.
Saw so many wet chickens full grind mode just now. Wet until like swimming.
My kid cycling with good airflow also face red red, took 2X aircon break (MBS and Maap LaB, washed faced MBS toilet and full wet the top)
quite significant cardiac drift
initially thought could be due to atmospheric pressure, but after checking, it was only around 1004hPa, which is not high at all.
me also wet chicken, shoes totally soaked.
yah, i can imagine myself in a worse condition if i run in SG now, feeling the heat from the ground while runningYeah we are also trying to acclimatize to the warm weather here in SG......but i think is mission impossible.![]()
Can’t sleep. Too energetic. Normally slept at 2-3am and woke up 6.30am. Trust me, U will feel energetic for the rest of the dayI got a question, are you able to sleep well after the run at 11pm?
Last time, I got a period of time when I used to run at 9pm. During my sleeping time at 11.30pm to 12pm, I can't fall asleep. Read up articles online and it's due to Adrenaline. After that, I don't really run at night liao.
Btw pangu running at Kallang Wave Mall already opened. Can go try bmai shoes
