- Mar 31, 2001
Maybe I can try….I'm placing it near my home window liao. Getting around 100mbps.
Hope it gets better.Maybe I can try….![]()
you try your new router with the VQ connection.Different router. The sim router is all in one.
My viewqwest modem is connected to a Xiaomi wifi router. Last time was ok one, then after the major downtime recently, become like that already. At night even worse, hover around 0.2-0.5mbps only, can't even watch YouTube smoothly.
But put near window got more dustHope it gets better.
It's ok. I most likely will be going the sim router route, more flexible and cheaper.you try your new router with the VQ connection.
xiaomi routers not known for their reliability.
and you should always diagnose which part of your network is causing issues before shooting down the ISP.
Put sim card inside can use sim card as router for internet.Mountain tortoise me
What is this for
This one got 5g?Top up abit for Asus XT8
Close the window.But put near window got more dust![]()
I mean, your VQ connection is still active whatIt's ok. I most likely will be going the sim router route, more flexible and cheaper.
Yes active but very slow especially at night. No reason to bash vq. I used to support them a lot but their reliability nowadays is atrocious.I mean, your VQ connection is still active what
or are you just wanting to bash VQ
Put outside window.Then will suffocate![]()
simple for you to diagnose the issue if you use your new router.Yes active but very slow especially at night. No reason to bash vq. I used to support them a lot but their reliability nowadays is atrocious.
yep recently a lot of issues, but TS' issue is not the same. he's getting 10 megabits down. but he also did not test direct connection to modem or try another routerRecently got issues with VQ .. like DHCP addressed to users all messed up, sometimes different fixed IP allocated randomly, fixed IP but get IP address conflict errors, etc. Quite random actually - bread and butter items you'd believe ISP hardware to handle.
a bit extreme to spring for a $300 Wifi 6 LTE router only to use a fraction of its potential...Haha, I think he sibei sian from the issues since mid April - early May.
Okay la, as long as got new working internet and no cap - should be happy
