Redmi Pad 2
Xie_Minghao
It's laminated. I'm looking at mine right now.
When you write with the pen, there's no gap between the pen tip and the line.
So how your experience with the tablet? I got a ipad and 1 galaxy tab s10 plus, thinking to get this tablet for on the go and usage in the bed
Parka
Display is bright vibrant and sharp. Sound quality is good. Performance is smooth enough.
But if you already have ipad there is no point to get another tablet
tmster
Anyone knows in Lazada , there are Xiaomi official store and Xiaomi SG store. Which is real ? Are they both legit?
Don't buy from Xiaomi SG Store. Had bad experience with them. They made a mistake with the order and don't want to solve it. Basically you are on your own after sales, they won't bother with any kind of follow up service.
I believe Xiaomi SG Store is not the official one, as i tried to check my order directly with Xiaomi and they mentioned that if it was purchased from their official store on Lazada, they will have the records. They couldn't locate mine and therefore cannot assist further and suggested that i check with the dealer. If prices are not much different, get from the Xiaomi official store, save yourself the trouble dealing with bad customer service.
froztheart
Tablet is decent, works fine for simple work usage, web browsing and entertainment etc.
Can grab at $250 or below for those interested.
