Samsung LCD Green Line issue seem quite widespread
marshalTan93
From chatgpt:
If you want a phone that does not use Samsung OLED panels at all, you’ll want to look for models that use displays from BOE, LG Display, Tianma, or Visionox. Here’s a list of phones (and series) that are known to use non-Samsung OLED panels, though panel suppliers can vary by region or even batch:
1. Apple iPhones (Select variants)
  • iPhone 12 – 15 series: While many use Samsung panels, some batches use LG Display or BOE panels (especially for non-Pro models like iPhone 13 or 14).
  • Check model numbers (A**) online** to confirm specific panel suppliers.
2. Huawei / Honor
  • Huawei P50/P60/Pura 70 series: Use BOE or Visionox OLEDs.
  • Honor Magic5/Magic6 series: Often use BOE or Tianma OLED panels.
  • Huawei and Honor aggressively moved away from Samsung due to trade tensions.
3. Xiaomi / Redmi
  • Xiaomi 13/13T series: Some models use TCL CSOT or BOE OLED panels.
  • Redmi Note 12 Pro/13 Pro: Often use Tianma or CSOT panels.
  • Avoid high-end models like Xiaomi 14 Pro, which typically use Samsung panels.
4. Vivo / iQOO
  • Many iQOO models (like iQOO Neo 7, Neo 8) use BOE or Visionox panels.
  • Vivo X90 (non-Pro): Uses BOE panel; X90 Pro+ uses Samsung E6.
5. Realme
  • Realme GT Neo series: Often use BOE or Tianma panels, depending on the model.
Quick Tips to Avoid Samsung Panels:
  • Avoid Samsung phones, obviously.
  • Avoid high-end flagship phones, which tend to use the best Samsung panels (like E6/E7).
  • Look for Chinese brands (Huawei, Honor, Vivo, Xiaomi) mid-range models — they frequently use BO
That's quite a lot of Brands not Including others like OnePlus & Nothing.
Basically almost all high-end models like Apple IP16, S24/25, 1+/Nothin/XM flagships....
Unless buy obscure brands like HMD or Nubia or budget XM(Poco) than can siam this thing.
Think saw a online complain oversea that some phone whole screen turn green. Wonder what's that ?
loganrunning
or check out display panel before buying. last year, 1+12 not using samsung panel, so i pull trigger.
so far, so good.
sounds like my s21. just before 2nd anniversary:
day 1: 2 lines (day 1 == day when 1 green and 1 purple line appeared)
approx 2 months later: 8-10 lines (mix of green, purple, white lines). left in drawer.
approx 2 months later: took it out, suddenly all multiplied, about 40% of screen obscured. not useable at all.
if i had waited 2 more months, won't be surprised if almost whole screen covered.
CCCustom
From chatgpt:
2. Huawei / Honor
3. Xiaomi / Redmi
4. Vivo / iQOO
5. Realme
I like how you’re suggesting BOE is a good panel brand … I repaired several laptops and from all discussions on screens, there are people who treat what brand screen they get in their laptop like a “screen lottery” … with LG being the lottery winner, AU Optronics and another brand starts with H (can’t remember the name) being not-great-but-at-least-better-than … and with BOE being the “better luck next time” brand.
layzibum22
Side note for those replacing their curved LCD panels.
The X Plus Premium protectors are very good.
The automated cutter cuts to the phone model. And of course the person installing it would need to install it well.
I think it’s even better than the default ones that Samsung gave in their earlier phone models.
Has a 6 months warranty to go back to the show reapply.
A little bit costly, but a very solid protector for Samsung curved screens.
