BlackWing1977
- Mar 1, 2006
Just enjoy first lor... actually need to burn in one meh?Juz got my castor pro. Waiting for burn in, any other to recommend? Wire? Tip?
Yeah but I find the larger ear tips ok because easier to hear my boss calling meJust enjoy first lor... actually need to burn in one meh?
Cable I think doesn't really do much except it feels different from the default.. ear tips is for comfort.. so test if you get a good seal and comfort for your default ear tips... I think castor pro they give you slight bigger bore ear tips.. as the nozzle on it is quite large.
Vader Pro if you choose with microphone, it came with the upgrade dual microphone cable.
Important Disclaimer: TL;DR - Do not buy these adapters. The charging case has an issue when plugged into high-wattage USB PD adapters, that will invariably brick them.
