SantyBalls
- Dec 25, 2022
I asked chatgpt to help me decide. I still undecided ðŸ«Haha this is to help who decide? I thot u are deciding which of them is better to get?
means note 14 pro+ can use 3 numbers at once? 2 physical sim card, 1 esim?It missed out the fact that the Redmi has Esim while the Poco does not
Nope. Dual only. Max out at two numbers. But u can activate or deactivate multiple esimsmeans note 14 pro+ can use 3 numbers at once? 2 physical sim card, 1 esim?
Redmi NOte 14 Pro+ at $349 from Xiaomi official store on Shopee... have to use seller and shopee voucher...
$80 diff between the 2..
redmi note 14 pro+ $349 poco f7 $430
Don't recommend F7, the last good Poco plain vanilla version was F5.I asked chatgpt to help me decide. I still undecided ðŸ«
The tech haven't rollout/mature yet to have such functionalities.means note 14 pro+ can use 3 numbers at once? 2 physical sim card, 1 esim?
Why not f7? Heat issues?Don't recommend F7, the last good Poco plain vanilla version was F5.
Been an extensive user of F series, owned F13/4/5. Since the 6 series, the plain vanilla version is always priced at the awkward area (not providing better value than X7 pro/F7 pro)Why not f7? Heat issues?
Haha i was thinking how they do it. Like 3 IMEI?The tech haven't rollout/mature yet to have such functionalities.
Any device only allows up to 2 concurrrent SIM nia.
F7 pro is $560Been an extensive user of F series, owned F13/4/5. Since the 6 series, the plain vanilla version is always priced at the awkward area (not providing better value than X7 pro/F7 pro)
For F7, why I wouldnt choose - aesthetics. Global version is plain ugly. China version main selling point was its premium looking aesthetics but the changes in global v color coding is just horrendous.
Another deal breaker is the chipset it uses. Gaming performance is even worse than X7 pro processor. Poor thermal controls and high power consumption with a smaller battery size, coupled with a bloated HyperOS system will make everyday use a headache. In India, got users saying that even at idle mode, the temperature of the phone is 45 degrees with a metal body frame and Singapore's weather, you won't want to burn your hands.
Value wise, pricing no good. China's pricing already dropped to 250-300 in their recent sale. Even at this price, I won't take because this chipset is not suitable for our climate.
It will probably be even cheaper on 7.7 sale. Because the $30 poco voucher is still valid and there is a $77 off $400 spend shopee voucher.Yup I never say xm change price, just saying some of us got screwed![]()
Worth or not, it's up to you, it's your moneyHaha i was thinking how they do it. Like 3 IMEI?
Or second space sort of stuff
F7 pro is $560
F7 is $430
F7 pro worth 130 more?
China f7 pro is half sg price?
Global rom is always more expensive. If you are just getting a secondary phone, china roma are still alright. If for primary phone, better to get global rom, less headaches as china roms sometimes got issue with some of the apps.Worth or not, it's up to you, it's your money
Just for reference, china equivalent models pricing for the recent 618 sale, the price you could get inclusive of tax and delivery
F7 (Redmi Turbo 4 Pro) $300++ I didn't monitor this model as I wasnt interested
F7 Pro (K80) $390-$450
F7 Ultra (K80 Pro) $550-$650
If your budget is limited and need global rom, just get X7 Pro for $350 or less.
Or you want good gaming performance and don't mind china phone, Iqoo Z9 Turbo+/Iqoo Neo 10 can be bought for $300-400
https://m.gsmarena.com/poco_f7_vs_poco_f7_pro_review_battery_camera_price_compared-news-68412.phpF7 pro is $560
F7 is $430
poco f7 $430
poco x7 pro $419.00
both poco f7 and x7 pro has IR blaster.
https://www.mi.com/global/support/faq/details/KA-577311#:~:text=3. Q: Does the POCO F7 support the IR blaster? A: Yes, the POCO F7 supports the IR blaster feature.
Cfm oneIt will probably be even cheaper on 7.7 sale. Because the $30 poco voucher is still valid and there is a $77 off $400 spend shopee voucher.
i think you are right about x7 pro and f7.
F7
AnTuTu: 2,024,751 (v10)
GeekBench: 6,402 (v6)
3DMark: 3,953 (Wild Life Extreme)
X7 Pro
AnTuTu: 1,568,331 (v10)
GeekBench: 6,311 (v6)
3DMark: 3,880 (Wild Life Extreme)
their performance benchmark is really close.
at first i deciding between F7 and note 14 Pro+, since note has IR blaster.
now I google their FAQ they say F7 also have IR Blaster.
so is see whether you want MTK (X7 Pro) or SD (F7).
You need to buy $1 more to use the $70 voucher.updated shopee prices :
redmi note 14 pro+
12+256 $349
poco f7 POCO Official Store + POCO Official Store Global
12+256: 529 - 30shop - 70shopee = $430
poco x7 pro POCO Official Store Global
12+256: 429 - 20shop - 60shopee = $349
12+512 : 459 - 20shop - 60shopee = $379
F7 for similar performance benchmark ratings, feels the additional $80 not worth it.
imo wait few months, probably around 11.11, f7 drop to sub 400 then its worth it. longer software support better battery life for ~50 more.updated shopee prices :
redmi note 14 pro+
12+256 $349
