I Lođź’–ve Simbaâť—
Flexamoria
Ayah, to be frank every telco also got people jjww one lah. If not there will only be 1 telco that every subscriber in sg support.
Find me 1 telco no one jjww....
U all cannot like that one
I seriously consider, but must think hard as a rock
firesong
Deluxe Member
Simba is my 2nd line. For spammable SMS/WhatsApp in SG, and for travel roaming.
Network is poor in SG, so I wouldn't rely on it.
wutawa
I used to ration out my data daily. Then towards end of mth had to use the throttled speed.
Lchlch
“More good news! Your plan has been upsized to 400GB for use in Singapore, Malaysia, Hong Kong & Indonesia; Local SMS increased to 100, at no extra cost. SIMBA 5G - Simply The Best!”
1st was new port in gets $20 foc, then 1 for 1 top up. Now upgraded foc to 400gb and 100 sms
How much per month?
kuti-kuti
How much per month?
I port over afew months ago on the $10 for 300gb with $20 free credit. Then following a few days they got 1 to 1 free top up, i.e. top up $20 get free $20 credit. Now i have credit till end oct 2025
Basically now $10 for 400gb
Lchlch
Better than 8.
swenson
reception no as great as others, especially indoors.
Office and home only 1-2 bars, but usually it is ok for me because these 2 areas are covered by wifi.
Otherwise outdoors is usually full bar LTE or 3-4 bars 5G
MRT tunnel definitely very bad but its ok for me too cause driving most of the time.
but roaming partners very strong.
Certainly suitable for me at current lifestyle
maggoth
Yall should write in to complain with screenshots of speed tests. I did that when I initially started with SIMBA as I had very poor connection at home. After a while improved and I now have no problem for my house area.
