[Official] SingTel SIM Only Plans
sacredrays
can la. Depends where you are at. Under or near cell tower or indoor repeater
i rmb when singtel first announce 5g+ roll out few months back, i did speedtest and get near 1gbps, recently i recon to the $15 (from $20 plan 12 months ago) i can never hit over 300mbps liao.. i did not change any other variables, tested with my older 4g sim card and then changed to the newer 5g sim card also similar speed.
my family member on s plan from years ago can hit 600+ mbps on s22u at the same spot.
Jurong640
hmm. that is weird, is the APN still the same? I'm currently using Zym singtel mvno, with 5G NSA, I'm able to hit 1.2gbps. Doesn't sound right if 5G+ gets lower speeds.
sacredrays
i dun think there is any changes. singtel (postpaid). but nvm ba, i dun need the full speed.
Jirachi
I can’t even hit 300Mbps most of the time as well. 5G Core Plan.
sacredrays
most likely is 5g nsa, which gives 4g speed of around 90mbps or so.. depending on your phone if can select 5g sa mode only, mine need to change network operator from automatic (singtel) to manual scan and select singtel 5g.
but pointless ba, i test test a bit only 300mbps so i just switch back to automatic sua liao.. :ROFLMAO: :ROFLMAO:
Jirachi
I am on 5G SA and the FTM Dashboard also shows SA.
swathe
Seems like can port out to eight then port in to vivifi for free 9 months
swathe
Seems like someone in Circles annoyed Singtel mgmt and they are getting their MVMO partners to kill them.
then i duno liao.
for me, when connect to 5g nsa i get 4g speed, 5g sa get around 300mbps
Indeed the speed does not really correlate well with 5G SA or 5G NSA. I think it may have more to do with the location.
I got pretty good speed like 545 Mbps recently with 5G SA in Jurong Point.
But just now I checked in another location and I got only 131 Mbps with 5G SA and 112 Mbps with 5G NSA. I am using SingTel SIM Only plan (S$20.37 per month now).
The top speed I got for SingTel 5G was 1118 Mbps back in Sept 2023, next to SingTel Jurong Point Shop. Never hit such high speed later. In fact, it was not so difficult to hit above 700 Mbps in Jurong Point last time but now seems to be difficult even to hit above 600 Mbps.
BTW, now it seems 5G+ displayed on the phone status indicates SA and 5G indicates 5G NSA, at least for my Poco X4 GT Android phone.
sacredrays
maybe my area did some infra upgrade recently idk ba. i was able to hit 1gbps sitting at the same spot back in May. recon at end of jun.
Jirachi
This is quite weird because I get better speeds and latency with MyRepublic 5G SA.
I see 1000Mbps+ often and pings are below 20ms.
I am not worried about top speed as there is really no difference between 100 Mbps and 1000 Mbps for a mobile phone. The speed degradation may be because of the congestions in Jurong Point area.
More important thing is that the coverage in Jurong West area for Singtel 5G is much better than last time.
But now you mention the ping value of below 20ms, that is really good. I have never seen such good ping value from SingTel when carrying out SpeedTest with SingTel 4G/5G.
