itedino
- Sep 13, 2003
Ask yr kid to claw inside and pickCare to share some tips?
Some of the local arcade don’t allow you to take the toy out yourself even when you have got it. You will need to call for them to come and open the glass to pick up the toy for you.Ask yr kid to claw inside and pick
Erm, meaning play a round of two to see if the grip is good. Good continue play, no good pass?Test the grip first. If it’s total no grip or those touch and go without even lifting the toy up one, you should not continue to play.
If it can lift up, then you can try to claw it towards the chute, aka hole, and hope that it drops nearer to the chute. Like that slowly drag near and hope like what I did in the video that I’ve posted just lor.
YesErm, meaning play a round of two to see if the grip is good. Good continue play, no good pass?
Yes. Some set as high as $120-150 for a toy that worth $20-30.Think got saw somewhere mentioned these machines generally are programmed to have a firmer grip in certain numbers of tries. Thus control the win rate in certain sense. Some needing more tries, some lesser tries, depending on the value of the items maybe?
No. Largely depending on the machine manufacturers. That’s why many will use the dragging or bouncing method.If so, does the grip increase in and drop in intensity gradually?
One free way is the watch others catch. That will gives you a gauge. Also take note that some of the claw will spin as it lowers. So aiming have to factor this in.If so, then can test grip bah. If not, think harder to gauge maybe?
Generally for such stuffed toys, how many tries then can get one ah?Yes
It depends.Generally for such stuffed toys, how many tries then can get one ah?
